Question about Cameras
Connection the photo controls selcon AS2403A to fluorescence
The connetion
On a 4 2x2 fluorescent. The inverter shots up wen turning them on and a alarm and red light come on.
Using portable power for a fluorescent light - Photo.net Lighting ...
photo.net > ... > Lighting Equipment and Techniques > Fluorescent lights
Jun 13, 2009 - 8 posts - ‎4 authors
so from a 12 volt battery, the inverter will take something like 20 to ... tube is ignited, it has a quite high current consumption (except when ... I considered the initial start up for fluorescent lamps and I'd certainly power this light up slowly! ... devices, and are insanely sensitive to the waveform powering them.
How To Shoot With Fluorescent Tube Lighting - Envato ...
photography.tutsplus.com/.../how-to-shoot-with-fluorescent-tube-lightin...
Sep 23, 2010 - I just mean, you should plug your lights in and let them run for several... For this shot, I simply set up the weight on a neutral-colored platform with a ... The long shape of the fluorescent tube when lighting a long curved ... Turn Captions On ...tungsten that you can get an inverter and power these off batteries.
Dec 28, 2015 | Inverter Electronics - Others
How do i download my photos from my camera to my laptop without my cable connetion
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
Jan 09, 2015 | Samsung Digimax S600 Digital Camera
Security light does not cme on
check bad if not it will be a bad light sensor
Jun 20, 2014 | Cooper Lighting AL65FL 65-Watt Fluorescent...
Have a cooprindustries outdoor security dusk till dawn light wont turn on
1 - verify the unit has power to it.
2 - verify bulb is functional.
3 - light sensor is functional.
Dec 07, 2013 | Cooper Lighting AL65FL 65-Watt Fluorescent...
Testing photo cell
These devices typically require a minute or two to change state from ON to OFF when the the threshold of light and darkness is reached. Place black electrical tape over the sensor and allow a minute for it to turn the light on. Make sure that no light shines into the sensor or that the sensor can not see light in the night time.
Lastly, double check instructions and wiring. White should be connected to BOTH the neutral incoming power AND the light fixture's white wire(s). Most times, black is 120V source, and red is the switched 120V out to the fixture.
If it isn't working, make sure the lamps are good. This photocell is suitable for use with compact fluorescent lamps, fluorescent lamps and other fixtures that use ballasts and transformers as long as they do not require more than 840 VA.
Dec 29, 2012 | Carlon Home Products Wired Photo Cell Post...
I HAVE NIKON COOLPIX L11 CAMERA BUT I WANT TO CONNET TO LAPTOP BUT IT IS NOT DONE ,WHILE ALL WORK ARE DONEWELL WITH OUT USB CABLE BUT CAMERA DATA HAVE NOT CONNETED TO LAPTOP PLE SOLVE THIS PROBLEM
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Mar 10, 2011 | Nikon Coolpix L11 Digital Camera
Better photos in florescent lighting
You need to adjust the white balance setting.
This is on the shooting menu.
The options on the white balance presets are.
Flash, Cloudy, Daylight, Fluorescent, Incandescent
Fluorescent is what you are looking for.
Remember to change it back to auto for outdoor shoting.
Jul 20, 2009 | Nikon Coolpix S560 Digital Camera
HOW TO CONNECT PS3 MULTIMEDIA REMOTE TO MY PS3
try going to register devise on your ps3 in the settings kind of like how you registered your controller.
Mar 24, 2009 | Video Game Consoles & Games
I restored my modem and I lost my verizon connection
Ok there are few steps to solve the problem
  1. goto My network places and make the connection
  2. double click the make new connections and select which country and enter zip code of your country. and select tone or pluse.
  3. enter the new connetions.
  4. After finish that the window comes like welcome to network connections wizard.
  5. choose which connetions you are using like dial up or boardband connetion which high speed
  6. follow the wizards and select the region and connetions of which type internet and zip code.
These are modem connetions of intial part of the connecting the internet.please inform me any other .
Apr 30, 2008 | Computers & Internet
Cameras Logo
232 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
