I have a dell studio pp39l and when I press the power button it just continually beeps and does not boot up. What is wrong?
  • 7,627 Answers
Cpu, Memory, HDD, hardware issue,Take a look at this Dell forum: http://en.community.dell.com/support-forums/laptop/f/3518/t/19436289.aspx
Posted on Apr 19, 2013
frcs68
  • 1605 Answers
SOURCE: Dell Inspiron 8500 doesnt continue boot up
is the crackling noise constant?
if so, your hard drive is lockup on the bootup. you have to get a new hard drive.
or you can try to reformat the hard drive, but I don't think that will help.
Posted on Jan 03, 2009
Pyrhyc
  • 2028 Answers
SOURCE: T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Posted on Aug 30, 2008
nileshsingh2
  • 246 Answers
SOURCE: press power button and i hear 3 loud beeps,
check if your memery ram is ok, change with same type...other options are, take your hard disk out then on your system, change your cmos battery...if wont able to solve then goto... www.acer.com
Posted on Oct 20, 2009
khanartist81
  • 80 Answers
SOURCE: on a dellmodel pp39l when the power is turned on
I could not find any beep codes that show only 2 beeps, please refer to the Dell Support website to find out what beep code best matches what your laptop is doing
http://support.ap.dell.com/support/edocs/systems/pe650/en/sm/beep.htm
Have you recently taking apart your laptop? If so then double check to make sure the RAM is seated correctly, remove the battery plug in only power and try turning on the laptop.
Please rate if this helps,
Posted on Mar 14, 2011
SOURCE: Dear, i have DELL studio PP39L
load defult seeting on your bios.or upgrade bios.
Posted on May 26, 2011
Dell studio pp39i while powering on no display and continous duble beep
It might be a problem with your motherboard. Contact the dealer.
Jul 16, 2012 | Dell Computers & Internet
Dell 1749 won't boot power light flashes 3 times
You've got an issue with your Memory or the Video Card.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, Remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 15, 2012 | Dell Studio 17 (1749) Laptop black -...
I have a Dell Studio Laptop-Model No. pp39l; Windows 7. I cannot start Windows. I did a system recovery with success but it still will not open Windows. It said to do a Windows Start Up Recovery, No...
Press the Fn key while powering on the system, this will launch the PSA diagnostics. See if you get any hardware errors (I suspect you may have a failing hard drive)
Jul 13, 2011 | Dell Studio 15 Laptop
On a dellmodel pp39l when the power is turned on it beeps 2 times and doesnt start up
Mar 14, 2011 | Dell Computers & Internet
I working on my sister Dell Studio laptop. Her son got a hold of it and pressed the power button several times while pressing several buttons. Now the laptop does not boot correctly. I power it up and the...
Remove battery and AC power, press power button for 30 seconds. reconnect ac power and try again.
Also check the hot keys (brightness) usually Fn and F6, see if that help
Dec 29, 2010 | Dell Studio 15 Laptop
Sir i am having laptop dell pp39L cd stuck in cd drive not able eject. please help me
you can find the eject button immediate right to the F12 KEY.(THIS IS FOR DELL PP39L LAPTOP)
IFit helped u say thanks..
Apr 30, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My dell studio 1735 will not turn on
You mean you have no display in your monitor?If it is the problem. Then your computer has something wrong with it. Did it beep several times while you turn your computer on?There are different types of beeps and it gives different meanings. I suggest it is better to take your computer into a service center and have it check by a qualified technician. Comments please for further assistance. Thank you..:-)
Dec 17, 2009 | Dell STUDIO 1735 Motherboard - H274K
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
