''on'' button will not turn on lap top.
I have an old Compaque lap top computer. It will hold a charge and is getting power but will not turn on. Can this be repaired?
thanks
gayle
    Genius:
  • 1,239 Answers
Hi Laptop won't power on?
If your laptop won't power on or stay on, check a few things:
1.Ensure your battery is holding power. Some laptops will auto shut-off if the battery won't hold a charge. In that case, replace your battery and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
2.Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. Replace it. Note- high heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (to touch), then this is not good.
3.Check your power cord. Are there nicks or cuts? If so, unplugg it from the AC power and repair with electrical tape- better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap.
4. Check your laptop lid switch. If it is broken, you may have power but your screen may not come on. This is usually a little button or mechanism located close to the lid hinge that turns on or off your screen when your lid is open or closed respectively. Normally the operator does not push this button. These are fragile and broken easily on some laptop models. Sometimes these can be fixed, more often they will require replacements. If you aren't an expert repair person, get a technician to repair/replace it for you. Opening up laptops is a very delicate operation and much more difficult to repair than desktops. It may be worth it to spend the money for repair.
5. If you have tried these easy solutions and it still won't power on, then your problem lies elswhere. You may have an internal power switch or voltage regulator problem.. Internal problems will require professional help.
Also, if your laptop powers on, but nothing is shown on the screen, it may be that the screen backlight or invert has gone bad. If you shine a light on the screen and are able to see something running (barely), then there's no reason to replace the entire screen (which is expensive), but with a little research you can figure out how to get the replacement parts for the backlight and inverter; there are also online guides for opening up the laptop and replacing these specific parts.
thank u.......
Posted on Mar 11, 2009
  • 4,806 Answers
Hi there.
It could be a fault with the battery itself or possibly a bigger problem like the power board or motherboard.
Take the battery out of the laptop and try turn the laptop on using AC power only, if it turns on there is a problem with the battery or power board and chances are you will be able to have it repaired.
Good luck and thanks for using FixYa!!
    Novelist:
  • 148 Answers
do you see the compaq logo when you start the laptop.
awaiting reply
  • ltoso Mar 11, 2009
    If you don't even see the compaq logo then take out the battery of the laptop and put in the ac adapter and try to start the laptop, if it works then it could be battery problem
    Further Queries are welcome
    Brigadier General:
  • 3,614 Answers
could be a defective battery pack
  • micromaster
    micromaster Mar 11, 2009
    this can be replaced but not be repaired. well i think you dont have a problem on the powerboard while charging it could be a battery of your laptop
Screen total black out
turn your lap top off, take out the battery, hold your power button for 30-60 secs, turn it back on and PRESTO!
Feb 13, 2012 | Fujitsu Siemens AMILO Pro V2010 Notebook
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
Lap top was working about 5 days ago I plugged in the charger today and it is not making a good connection I have to wiggle it to get the charge light to stay on also the power button has fallen off the...
Is it under an extended warranty or even under a 1 year warranty?
That's unfortunate that the power button has fallen off and the hinge is hanging by a wire.
I would have it repaired at an authorized repair shop for your make and model.
I wouldn't try to use it in that condition, it could be dangerous electrically.
Jul 13, 2010 | Computers & Internet
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
MY SAMSUNG R60 LAP TOP WONT WORK.. THE USER GUIDE IS INSTALLED IN THE COMPUTER SO I CANT ACCESS THAT! IT IS DISPLAYING A RED LIGHT WHICH I THINK MEANS THE BATTERY IS FULLY CHARGED??? BUT NOTHING HAPPENS...
my samsung laptop is green when charged, red when charging.
try turning it on with the power adaptor plugged in and the battery removed.
if this works, i assume your battery is damaged
Oct 01, 2008 | Computers & Internet
Edge 305
Try Holding the Lap + Mode, for a few seconds, release and then hit Power button. It worked for me.
Cheers
Sep 29, 2008 | Garmin Edge 305 GPS Receiver
MY ACER ASPIRE 1640 LAP TOP WILL NOT STAR UP. WHEN TURNING ON THE POWER BUTTON FLASHES ON AND OFF. WHEN PLUGGED INTO THJE MAINS THE CHARGING LIGHT SHOWS YELLOW BUT THE COMPUTER WILL NOT TURN ON
check the power supply to the mains where the lap top is plugged and comfirm if there is power supply and for any possible drop in power output which may affect the charging
Aug 04, 2008 | Acer Computers & Internet
Garmin forerunner 305
My husband is the best!  Here's what he did and now it works:
Hold the on/off button and mode button, then hit the lap/reset button.
Hope this helps!
Jun 21, 2008 | Garmin Forerunner 305 GPS Receiver
Packard Bell 4451 lap top will not power up.
check the back of the power connector to see if it is loose. I have known alot of situations were, if not carefully removed, that power connector in the can free itself from the sodder on the Mother board therefore you wont be able to charge the battery nor boot up. hope that helps
Mar 18, 2008 | Intel Motherboard
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
