Purchased a used Konica 7165 w/ IP511 controller. I want to install driver & software on a networked Windows 2000 PC. Manual says to use Konica MAP software (which I don't have). Am I out of luck or is there a way around the CD? Thanks
  • 145 Answers
You may want to check konica web site ..or check with any ocal dealer for a driver
good luck
Posted on Mar 18, 2009
Konica minolta di 1611, di 2011 driver windows 7 32 bit. konica minolta di 1611, di 2011 driver windows 7 64 bit pozdrawiam Jarek
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Feb 10, 2011 | Konica Minolta Di2011
The disc i have says it is compatible with windows xp but i have windows vista how do get the pad to work for me pc games
http://rapidshare.com/files/362751095/Nyko_Airflo_Drivers_2.0.0_For_Mac_and_WinXP.zip
Heres the latest drivers from my cd of the airflow controller. Works with Windows 7 too
Apr 02, 2010 | Nyko Airflow EX PC Game Controller...
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
SCANNING PROBLEM KNOICA 7165
contact whit the engineer probably u have to instal new firmware
Jun 23, 2009 | Konica Minolta Office Equipment & Supplies
What is the code to manually clean the corona wire Konica 7165
47 mode output 046 p00p for charge 47 mode output 047 p00p for transfer
Apr 03, 2009 | Konica Minolta Office Equipment & Supplies
Bizhub C250 - Vista software
hello,
you have to install konica minolta c252 driver and software application. c252 adn c 250 are similar model.
You can download it (for windows vista) to konica minolta web site.
Bye
Nov 22, 2008 | Konica Minolta bizhub C250 All-In-One...
I HAVE JUST PURCHASED A NEW COMPUTER , WHICH DOES NOT HAVE THE OPERATING SOFTWARE INSTALLED. THE QUESTION IS: THE MANUAL THAT CAME WITH THE UNIT SAYS TO FIRST RUN THE CD THAT CAME WITH THE UNIT THAT WILL...
If you do not have the original disks that came with the computer, yes load Windows 2000 Pro.
You will then need to download drivers for any that are not found by the OS.
Hope this helps!
Mar 24, 2008 | Computers & Internet
Konica 7255 diaplays a F56-04 code when IP is installed
That is correct. The IP511A is for the 7255 / 7272, and the IP511 is for the 7155 / 7165.
This is probably due to these machines using different image processing boards.
I am actually surprised it lets you get as far as you did with it.
Feb 08, 2008 | Office Equipment & Supplies
353 people viewed this question
k24674
