Question about Samsung Ds-24d 24 Button Display Phone For The Ds616 Refurbished Year Warranty
How to get an incoming call to switch to the other free line on DS 24D
When we are on our primary line and another call comes in we hear the beep but can do nothing and often lose the call. We need to set the phone up so the call diverts to our other phone line when the primary line is busy.
3 Suggested Answers
  • 521 Answers
SOURCE: NEED TO CHANGE NUMBER OF
can u explain more precise
Posted on Aug 28, 2008
PhoneSystems
  • 213 Answers
SOURCE: samsung ds 24d - how
hi, this is a feature which is in engineering programming, if you have access to this the MMC required is 501 the codes are 'Sys Hold' and 'Trans Hold', If you don't have access, you will need to contact your Telecoms maintainer. Alternatively you could use the exclusive hold, check out this site for more information - http://www.abbeytelecom.com
Posted on Sep 22, 2011
How do I set up the call divert on our NEC DT300 Series phone so that all incoming calls are diverted to another land line? The info on the back of the phone is - NEC DT 300 Series DTL-24D-1A(BK) TEL...
I am not sure which country you are in, but in Australia your divert depends on your phone carrier not your model. If your carrier and call plan supports call forward you just dial their set number and follow the prompts to turn on or off.
Oct 22, 2013 | NEC Lands Phones
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Samsung DS 24D Phone System WHILE ATTAENDING INCOMING CALL NO BEEPING IS HEARD FROM INTERCOM CALL
this is an option to ring or not to ring while on a call. Your local phone man should be able to help you with that basic programming
Dec 09, 2008 | Lands Phones
CS70N Wireless headset
The earpiece will make 3 short beeps when a call is incoming. Also the phone will still ring if you are within distince to hear the ringer. Hope this helps! SM
Sep 10, 2008 | Plantronics CS70 Wireless Headset
No 3 beep notification in the earpiece of an incoming call
I had the same problem and the cause was the handset lifter and not the earpiece--if the ringtone is too low at the lifter, it won't be detected and transmitted to the earpiece. Cranked up the ringtone and everything is fine.
If that doesn't take care of the problem you might look at whether or not you're using custom ringtones which might cause a problem. Switch them back to the defaults and see if the problem goes away.
Nov 28, 2007 | Plantronics CS70 Wireless Headset
Phone does not ring
have you called the support line for assistance?dial 1.800.511.3180
Oct 12, 2007 | RCA 25414RE3 Corded Phone
Fax machine beeping - Samsung SF5100
YOUR PROBLEM IS NOT VERY CLEAR,PLEASE TELL WHETHER--- A. DO YOU GET DIAL TONE ON THE MACHINE? B.WHEN THE MACHINE GETS INCOMING RING -IT IS SET TO ANSWER ON HOW MANY RINGS ? C. SWITCH OFF THE DRPD MODE. D,CLEAR THE MEMORY OF THE MACHINE TO FACTORY DEAFULT BY--SWITCHING ON THE MACHINE WHILE HOLDING THE STOP BUTTON AND THEN COOSING YOUR COUNTRY WHEN PROMPTED. SHOULD TAKE CARE OF THE PROBLEM... HAPPY FAXING OMNIPRESENT
Sep 25, 2007 | Office Equipment & Supplies
Samsung Ds-24d 24 Button Display Phone For The Ds616 Refurbished Year Warranty Logo
26 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
