Question about HP Pavilion HP A1000Y Desktop PC w/ Intel Celeron D 335 2.8GHz processor 2.66GHz (565953)
Very slow computer
It's just so slow. We have verizon as our server and don't know if we have to subscribe to a faster version or what programs to trust to help the computer run faster. I know there are free downloads of programs to help, but are not sure which of those is good. Or do we need to buy software? We just don't know how to speed things up.
  • judy_gerlach Mar 14, 2009
    Thank you Fixya people. Your comments were very complete and professional. I have not done everything yet, but am working on it. I didn't rate your info since I want to give it the top rating when it's fixed, not just the helpful rating. One more question...when I went to CCleaner, there are quite a number of them. Only the bare essentials seem to be free, so before I pay for one, is one better than the rest...or are some better than others? They seem to cost about $30 or $40 which isn't a huge amount. I am so glad to have read about your site in my local newspaper. Thanks again, and get back to me about the ccleaners, if you would. Judy
    Sergeant:
  • 219 Answers
A slow computer can be caused by a multitude of reasons, but it is not due to your Internet speed. Typically the most popular reasons are:
1. Too many things running in the background (including viruses, malware, and spyware).
2. A fragmented hard-drive.
3. A messed-up registry.
So, to check how many processes we have running in the background we press Ctrl + Shift + Esc. Once the task-manager opens head over to the processes tab. Here you have a readout of all processes running on your computer. At the bottom of the application is the total number of processes running. Typically for Windows operating systems you want the processes to be between 20-30 for good system operation. The processor (CPU) should also be jumping between 0 - 2 percent usage like a heart-beat while you're not doing anything. If any of your numbers are above the, "norm" you can expect slow-downs.
The first thing I would do to clean up a system is to head into, "Add/Remove Programs" located in the, "Control Panel." Once inside I will look for applications that I know I will not need or have no use for. Once I have cleaned up my system in this method I will download CCleaner (Which I know is free of malicious files). Once installed I will run the cleaner to clean up temporary files sitting on the hard-drive. Afterward I would defragment the hard-drive. In this instance the default defragmenting tool located in Start>Programs>Accessories>System Tools>Disk Defragmenter will work. However it is not as powerful as some of the payware versions, such as O&O Defrag. I recommend that you try out the 30-day free trial of O&O just to clean up your system. Once installed find a time period where nobody will be using the system for 3-5 hours. Then run a COMPLETE/Access defragmentation on all hard-drives listed.
Depending on how badly your hard-drive is fragmented you may have to run the same defragmentation process more than once.
After defragmenting I would use Auslogic Boost Speed to clean up more junk files, erase bad registry entries, defragment the registry, and even boost my Internet performance just a wee-bit. I'm not sure if Auslogics provides a free trial for their product, "Boost Speed." But if they do, you should download it just to help speed up your computer.
After finishing all these steps your computer should have sped up dramatically. If not, there's still too much running in the background. Go to Start>Run and type in: services.msc
After pressing OK the services window appears. PLEASE READ THE FOLLOWING CAREFULLY! If for some reason you stop a critical system-service, restart the computer. It will be started again upon the system restart. HOWEVER, if you disable or set to manual any of the services and they turned out to be critical services, they will not start upon a system restart and you could be looking at a re-install of Windows. So PLEASE research any service before deciding to disable it or setting it to, "Manual."
Within here you can define which services you want stopped, you don't want starting with the system, or you don't want starting at all. Some services are for popular applications installed on your computer such as Ipod services, Yahoo services, etc... Setting them to, "Manual" means they won't start with the system in turn freeing up the processor of yet another process allowing the computer to run faster, if even just marginally.
However, make sure to research any service you are uncertain about as setting it to manual or disabling it could be a very bad idea.
Let me know if I can help you further, or if I need to explain any steps in more detail.
Posted on Mar 11, 2009
  • Peter Steiert
    Peter Steiert Mar 14, 2009
    CCleaner is free. Always has been and as far as I know always will be. When downloading CCleaner, download from FileHippo (You can select to download from FileHippo through ccleaner's download page.) Here they will have all previous versions of CCleaner listed, as well as the most recent (which, naturally, is located at the top). To get the most out of CCleaner, download the newest version.
    Now as for Auslogics Boost Speed and O&O Defrag, I would buy both. Yes, Auslogics Boost Speed has its own defragmenting utility, however it is only good at defragmenting, and not migrating files for optimum speed. O&O is great at both defragmenting and moving files across your disk to ensure your most frequently used files can be accessed with optimum speed.
    Now as for buying Auslogics Boost Speed, the utility includes masses of extra programs which can be used to tune, tweak, and speed up your system and your Internet Connection. Auslogics Boost Speed is my favorite program as its, "got it all." Instead of having to download/buy all these seperate utilities which do their own thing to speed up your system, you have them all in one package with Auslogics Boost Speed. Plus you have a lovely interface which explains what the utlities do, and how to use them.
    Another thing you might want to consider is Computer Security. Viruses, malware, and spyware can slow down your computer as well as jeopordize your system's security. A free online scan (using Internet Explorer) from this website will let you know if you have any viruses. If you do have some form of infection and it was picked up by the scanner, it might be wise to invest in some online security software. Here are the utilities I recommend:
    Anti-Virus/Firewall: ESET Smart Security
    Anti-Spyware: Lavasoft Ad-Aware
    Anti-Spyware: Spybot Search & Destroy (Free)
    One suggestion. If you get ESET Smart Security or NOD32 Antivirus and then decide to download and install Spybot Search & Destroy, do NOT install TeaTimer.exe. During the installation of Spybot Search & Destroy you will be asked if you wish to install TeaTimer(.exe). You do not want to install TeaTimer as it interferes with the active monitoring abilities of ESET's Smart Security and NOD32 Antivirus.
    Once again, let me know if I can help you further or if I need to elaborate further on anything mentioned above.
Not downloading new emails
You may have to setup your email program settings:
This is what part of mine looks like:
Verizon / Yahoo Mail Server Settings
Outgoing (SMTP)Settings
Description: Verizon/Yahoo
Server Name: outgoing.yahoo.verizon.net
Port:587
User Name: **********
Secure Connection: TLS (if available)
Incoming Server Settings
Server Type: POP Mail Server
Server Name: pop.spamcop.net
port: 110
User Name: *********@spamcop.net
Secure connection: TLS (if available)
You can find these settings on your desktop computer and check to see if they match the laptop's settings.
Mar 08, 2014 | Computers & Internet
I need to clean up my computer
Goto C: drive icon in My Computer. Then click on Properties, then click Disk Cleanup. There is also on option to clean all but the latest restore point, that saves a lot of hard drive space.
You can also defragment your hard drive which sorts all the files out so that when a file is accessed it finds all of it at once, instead of finding fragments and putting them all together. Files are not usually stored all in one but are spread around the drive, taking longer to find the fragmented bits. It also consolidates all the free space for faster writing to the drive.
You can also go in to MSCONFIG and click the Startup tab and see what programs are running. Anything in there automatically starts running as soon as Windows starts. You can dissable the ones that you know don't need to be running. Not things like Antivirus, Firewall or anything to do with Internet though.
Go to the start menu and type msconfig in the search / run box and press Enter. When you have unticked the ones you dont want running restart the computer.
You will probably get a box pop up when you have restarted saying that you have been in to the configuration settings etc. Just tick the little box on the left that says Don't show this again or whatever it says.
You could also uninstall any programs that you don't actually use.
Go to the Control panel and click on Add and Remove Programs for Windows XP, or Programs and Features in Windows 7.
If it's just got slow gradually,cleaning up usually helps a bit.
If you just want it to be a bit faster then maybe it can have more Ram fitted on the motherboard, that helps, also upgrading the processor, and a faster hard drive will help.
You can also use a little program called CCleaner whhich searches the hard drive for all the rubbish left over from uninstalled programs, unused files, temporary files that are no longer needed etc. It's a free program and very popular.
You can also clean the registry which gets rid of a lot of rubbish left in there. There is an option in CCleaner whhich will do that.
Hope this helps.
Feb 10, 2012 | Toshiba Computers & Internet
My computer is very slow and I need not much time left standing
The reasons for a computer being slow could be either that you have a full hard drive low memory or possibly and more likely you have malware on it. first thing to do is run and anti malware program like Malware Bytes
Download the free version and allow it to update and run a scan. once this has been done your PC should run a lot faster.
If not check your hard drive free space if it is below 15% you need to delete some of your old files and programs to free up some more
Jul 23, 2010 | Dell Computers & Internet
Transaction replication is poosible in sql server devlper edition
SQL Server 2005 provides a lot of benefits over SQL Server 2000 including within the replication feature set.
You might be relieved to know that, although most of the benefits accrue on the side of a SQL Server 2005 Publisher, you can still set up SQL Server 2005 as a subscriber on a SQL Server 2000 Publisher. Thus, you can begin to merge in the newest release of SQL Server into an existing replication scheme. You can read more about this at http://msdn2.microsoft.com/en-us/library/ms217330.
Although major advantage to SQL Server 2005 over 2000 is that changes to the schema, such as through ALTER TABLE statements, replicate out to all subscribing servers. The cool news in a mixed version environment is that the ALTER TABLE statements will be published to SQL Server 2000 Subscribers from a SQL Server 2005 Publisher.
Very cool!
Jan 30, 2009 | Televison & Video
Phone oprating slow
They actually made a w920i?
But anyways, finding a good or any antivirus program for a UIQ 3.x phone is real hard.
To make your phone faster I recommend leaving antivirus software out and using this program to reflash your phone so it deletes everything from it and brings it back to factory settings. And try staying of website that you don’t know and don’t install some program that you don’t know what they are and you won't have problem with viruses.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w910i?lc=en&cc=gb
Good luck.
Jan 10, 2009 | Sony Ericsson W910i Cellular Phone
K1M Phone issue
at times issues like that happens when the memory card used have not been formatted or a corrupt file on the memory card the way out is to format the memory card through the computer or run a fix.thanks dont forget to rate as fix yaa
Sep 20, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Windows 2000 server
d_asit,
I highly recommend you read this guide from SpeedGuide.net - the guys there really know their stuff!
Please let me know if this helps. Good luck!
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Fix script page error
re-install the program internet explorer.
or go to ( On your computer ) Start/all programs/accesories/system tools/system information.
From there you should have an option to repair internet explorer.
Mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
Slow excel on network
have her log on to one of the other computers on the network and see if the problem follows her.
Dec 03, 2007 | Microsoft Office Xp Professional Full...
Slow downloads
Always update the router firmware ONLY if you have problems.
Run a DSL test to see if your actually getting the full speed inside the network.
www.DSLREPORTS.com <<--i believe but you can do a google search for broadband test.
I know with comcast you can unplug the modem for lengthy time, plug it back in so it pulls the most updated version off of comcast's server.
Nov 13, 2007 | Linksys Wireless-G WRT54GX Router...
Computers & Internet Logo
99 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
