Question about Mtd Garden
How do i change my oil huskee lt 3800 - Mtd Garden
I bought a 2017 huskee riding mower from tractor suply and i cant find the oil filter on it nore can i find a video on where to find it pleas help
Ask tractor supply, most small engines under 13 HP don't have a oil filter, check oil level every tank of fuel, if the level is dropping, if its black in colour or the oil is six months old in machine ,you need to change the oil.
Jun 25, 2017 | Garden
Looking for a LT 4200 huskee manual
Operator Manuals
If you don't find it, give them a call.
Also, here is a link for parts manual online:
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/13w2775s031-lt4200-huskee-lawn-tractor-2013/
Apr 27, 2017 | Garden
Huskee Lawn Tractor Manuals LT 4600
http://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/13aj771g031-huskee-lawn-tractor-2009-tractor-supply/
Apr 19, 2017 | Garden
I have a huskee 173cc autochoke ex start. It shuts off after a few seconds. I changed gas filter gas and oil and spark plug. Problem persists. What can I do??
Maybe the low oil level switch is bad. Disconnect the wire that goes to the low oil switch which is on the block of the engine and see if it runs longer. Make sure the oil level is to the full mark first.
Jul 01, 2014 | Cars & Trucks
I have a huskee lt4200, engine is a 420cc OHV.
Check for gas contamination in the oil....if the oil itself it gas free....its likely a blown headgasket.
Aug 05, 2013 | Briggs & Stratton Garden
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
3800 ENGINE IS EITHER NOT PUMPING OIL OR IS KCOCKING
Yes. It's always good to fill the filter prior to installing. Also try to lubricate the oring on the filter prior to installing. Priming the filter aids in getting oil to upper end of engine.
Jan 25, 2013 | Cars & Trucks
Firing order for plugs and wires....on a v6 3800 2000 impala
For the 2000 Chevrolet Impala 3.8L V6:
Firing Order:
1-6-5-4-3-2
Cylinders:
.....(back).....
|...2...4...6...|
___________
|...1...3...5...|
.....(front)
Ignition Coil Connections:
(back)
o <---6
___
o <---3
o <---2
___
o <---5
o <---4
___
o <---1
(front)
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Apr 18, 2010 | 2000 Chevrolet Impala
Garden Logo
102 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
