Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
John deere SX75 starter will not crank over
New battery, solinoid is getting power. Starter makes click sound, but will not turn over engine
  • 279 Answers
SOURCE: john deere 850 compact
There is a switch under the seat. Just to test and not to run, you can take a jumper cable and go around the switch. If you find this works, go get a new swtich. It is very important for safety...Good luck...Lee
Posted on Sep 04, 2009
  • 76 Answers
SOURCE: starter
motor problem. solenoid main function to start only.
Posted on Dec 31, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 316 the starter doesn't engage often.
You need to instal a starter relay kit.Deere part # AM107421.Mount it down by the starter,purple wire that goes to starter will now be plugged in to the relay,red wire to hot side of starter,black wire to a ground point,purple wire that is a part of new relay can now be plugged in to the starter.its very easy to install and fixes nearly 100% of clicking starter.
Posted on May 29, 2010
nova2nv
  • 197 Answers
SOURCE: I have a John Deere STX 38 riding mower. I am
In front of and to the right of battery is the starter solenoid,replace it.
Posted on Jun 25, 2010
SOURCE: john deere 4010 wiring schematic,diesel engine
Call me, or email me there are so many options, I would like to know exactly what you need. Solutions are simple, I have worked on AC and DC vurrent all my life and even have some designs on youtube, and have taught seminars for Delco, Leece-Neville/Prestolite, and designs for A/P and Twin Roter. Shmburns@yahoo.com
Posted on Dec 24, 2011
When I turn the key my engine just clicks and does not turn over , if I turn the engine past the compression stroke I can get it running and it runs fine put I have to turcompression every time t
Doesn't sound like your battery has enough juice , cranking amps to get the flywheel going. Test your battery and starter. If you have a multimeter this will help...
Oct 16, 2015 | John Deere Garden
John Deere 4230 new starter replace battery also and still will not start
Ignition switch, connections at switch, or small post on the starter solenoid, or wire broken between the two. Or possible bad "new starter solenoid". It's been a problem for other starters. May be a bad batch of solenoids. You may be alble to veryify the solinoid by a jumper from the positive battery terminal or cable to the small post solinoid terminal. If it activeates the starter, you know the solinoid and starter are ok and the problem is the wire or connection to the starter switch. If you had problems before, It may be a bad ignition switch and the internal starter switch. Did you test the old starter? you may not have needed to replace.
Mar 27, 2015 | John Deere Garden
Brand new battery - Starter not engaging
Prbably an issue with the solinoid, try jumping between the two heavy duty cables on the solinod with a suitabke screw driver BE CARFULL, if the engine cranks replace the solinoid
May 17, 2013 | John Deere Garden
Do you have a wiring diagram for the starter on a John Deere 285 garden tractor? The old starter was removed and no wires were labeled.
Generally starters ground through the engine, so that only leaves the positive wire. That one comes from the starting solinoid. Starting solinoid gets power from the battery. Anyway these wires are the biggest ones on the machine including the negative/ground wire from the battery.
I hope this helps.
Jul 30, 2011 | John Deere Tractor Starter 285 345 2243...
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Sep 08, 2010 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
280 LX won't start. Won't even click or turn over. Battery is fully charged. The trouble shooting manual notes it could be an ignition system fuse, and to contact a Deere serviceman. Is there an in-line...
i am currently working on an old jd 111 and the fuse is located under the starter solinoid, check there. The starter solinoid should not be located on the starter, track back the thick red wire on the starter to the solinoid to locate, it will be systematically located between the battery and the starter, check the starter solinoid functional with a meter and if that does not find it at the fuse and solinoid you will need to check the ignition switch input to the solinoid, and work back to the switch and any interlocks
Jun 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 425 AWS no start, no nothing???
Sounds more like a bad starter than a bad coil.
A failing coil usually shows up during hot weather. The engine will start and run fine, then when it heats up, it just dies out. After a few minutes, it cranks again. Then the cycle repeats itself.
The ignition module and coil pack are the same part.
Are you sure full voltage is getting to the starter? There is likely a starter solenoid between the ignition key and the starter. These solenoids can be problematic and prevent the full 12 volts from getting to the battery.
Oct 16, 2009 | Garden
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
62 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
