Question about Seagate Expansion 1 TB USB 2.0 Portable External ST910004EXA101-RK Hard Drive
Need a new raptor marina 2.5 main board
USB connector broke of.
3 Suggested Answers
  • 11800 Answers
SOURCE: hi i have a seagate
Yes, it can be fixed - all you need to do is to solder it back. Just make sure you do it properly - use good quality solder, a fine head soldering iron and lots of care.
The board can be easily replaced, but it's not sold as is, you will have to obtain a defective hard disk from a pc repair shop and use its board.
Posted on Dec 20, 2010
SOURCE: Hi I have a seagate raptor
Here's your solution, I had the same problem. Purchase Thermaltake Black Widow PC Gaming Hard Drive eSata + USB Docking Station (part number: ST0005U). I got mine at Best Buy for $55, but I'm sure you can find it online for much less. Good luck - trust me this works..... oh and by the way, dont buy a SATA-to-USB cable because your USB port on your PC does not provide enough power to the hard drive and you won't be able to access your drive.
Posted on Aug 06, 2011
Hi There I am trying to locate the raptor 3.5"
Apr 13, 2011 | RPM 20PK 150GB RAPTOR SATA 10000 16MB...
My sandisk cruzer 8gb was stepped on while in my xbox 360 and i wont light up nor come on when i hook it up to my computer how do i fix it
You could crack it open and resolder all the broken connections in it.. but.. your better off buying a new one. their a pita to repair.
Apr 11, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Broke off the USB connection from the board on the bottom of the drive. is there a way to replace this board to get it up and running again
Did you break the connector on the "enclosure" part of an external disk-drive,
or did you break one of the connectors on the "bare" disk-drive (not inside an enclosure) ?
If the former, then you can purchase a new "empty" enclosure, and "transplant" your disk-drive (with your files) from the "old" enclosure to the "new" enclosure.
If the latter, then you need to find an _identical_ disk-drive, disassemble it, to separate the "spinning" part of the disk-drive from the electronic circuit-board (with its connectors), and disassemble your disk-drive, and connect your "spinning" part to the "good" circuit-board.
Or, search online for a professional "file-recovery" service, who will do the same, for a fee.
Dec 16, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My daughter broke one of my usb ports in the front of my asus cm1630 how do i get replacment parts can i buy a usb 2 or do i have to buy the whole setup that contains the usb ports and media card slots
USB 2.0 refers to the technology, not the connector itself.
http://en.wikipedia.org/wiki/USB
Obtain another USB connector, and solder it in?
Sure, maybe. Depends on your de-soldering/soldering skills, and if the circuit board is damaged.
> Physically damaged in that the board is cracked, and circuit traces are ripped loose, (Repairable with a jumper wire, or wires), AND/OR the USB port was fried out (Short Circuit), and it fried out the entire circuit board.
Obtain another circuit board? This would be the way to go IMHO, but try to find one.
You may have luck on Ebay looking at Desktop Computers > Computers for Parts, or the actual circuit board itself, dunno.
1) http://www.mouser.com/Search/Refine.aspx?Keyword=USB+female+connector
2) http://www.radioshack.com/product/index.jsp?productId=2062744
3) http://www.mgchemicals.com/downloads/appguide/appguide0805.pdf
(PDF file. Takes approximately 20 seconds to download. {Time it takes also until you see the first page)
For questions post in a Comment.
Regards,
joecoolvette
Dec 12, 2010 | ASUS Computers & Internet
The prongs on the USB connector broke off. Do we need to replace a board and if so how do we do so?
You can buy new connector and replace broken one. You need skill at soldering and of course have to open the unit to access the broken connector.
Oct 10, 2009 | M-Audio M Audio Keystation 88es 88 Key USB...
Usb broke off my seagate 320gb external
it does'nt really matter IDE or SATA both are using same connector. you can change it from second hand or from another board sometimes its not available.
Sep 02, 2009 | Western Digital 320GB MyBook External USB...
Usb connector broke off can the data be recovered?
Yes, but it has to be taken to someone who can do soddering.. make sure you keep both pieces and check local shops for someone who can soder the connectors back together. the data is stored on the main chip, its just the connector that gone now.
Jul 07, 2009 | Electronics - Others
TV input on the back of the unit broke cant connect coaxial cable
Try entering the model number on website below, they do worldwide delivery, and have one of the biggest database of replacements.
Appliance parts, electronics parts & more from PartStore.com
Feb 18, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
Seagate Expansion 1 TB USB 2.0 Portable External ST910004EXA101-RK Hard Drive Logo
400 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
