Question about Delta Tools & Hardware - Others
What is the belt length on the Delta 31-080
What is the belt legth?
What size of belt for delta 1 inch belt sander?
you would have to list the specific model number listed on the side of the factory sticker for me to pull it up on their site..or measure from outside of the front wheel to outside of the other wheel on the rear. should give you an accurate belt length.good luck
May 19, 2017 | Delta Tools & Hardware - Others
What is the length of the 1 inch belt on the delta 1 inch belt/5 inch disk
You did not post enough information because there are more than one model anyhow most are 1" x 30" others are 1" x 42"
Dec 16, 2014 | Delta Tools & Hardware - Others
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Need serpentine belt routing diagram on a 2000 honda accord lx 4 cylinder
Take the vehicle to an Advanced Auto parts store. Purchase the belt or look in the chilton manual they have on the shelf. The belt comes with the diagram on the sleeve that comes with the belt. There may be a delta in the belt length if the vehicle does or does not for instance come with Air conditioning.
Nov 04, 2013 | Cars & Trucks
The pilot lite in my sears 10 natural gas furnace model 867764510 will ignite but go out a short time later.
simply replace the the thermo couple. Any home depot. Very easy.Be sure all doors are in place or it could cause the flame to pull away from the thermocouple. If the problems new, change it. 5 minutes literally. Shut off gas and get the correct legth(18,24,36,12 inches.
Nov 05, 2012 | Heating & Cooling
Gas peddle sticking
check to see if cable is proper legth spray cable with lubrication afterpulling cable out so petal is to floor
Dec 16, 2011 | 2002 Pontiac Montana
Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Feb 06, 2011 | Delta Machinery Delta ShopMaster DP350 12"...
What size belt does it use
You did not mention a model number, but the is probably the width of the belt and the 6 is probably the diamter of the disc.
The sanding belt size is probably a 4" wide by 36" long, but it may be 4 x 24" long. Put a string around the rollers, and then stretch the string out straight. Measure it and that is the belt length.
You can find either size belt at sites like http://www.2Sand.com and http://www.BuySandpaper.com
Jan 25, 2011 | Delta Machinery 4x6 Belt/Disc Sander
Tools & Hardware - Others Logo
503 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
