Question about Frigidaire FGQ1442ES Gas Dryer
I have a kenmore gas dryer.the door opens after only 10 minutes of drying.i have cleaned the exhaust hose,From the dryer to the outside. The start button is pushed all the way in.It is a manual not digital controls.Could it be the door switch? Is it safe to just jam the door closed each time.
  • Frigidaire Master
  • 3,361 Answers
The door latch is broken.
Replace it. About $5.00
Posted on Mar 11, 2009
Kenmore Elite HE3 not heating up when vent connected
check outside of house for any obstructions to the outlet. make sure the vent is clean
Jan 02, 2013 | Dryers
Kenmore 110.70982990 front loading gas dryer. Everything seems to work, except the flame stays on for only 5-10 seconds, and therefore does not produce enough heat. Lights up again after a few minutes,...
Remove the exhaust vent from the rear and try a load of laundry.
If ir dries correctly,clean and or repair the connecting exhaust vent.
It may also be necessary to disassemble the dryer and clean internal ducts.
Feb 20, 2011 | Kenmore 63942 Dryer
It is heating up but taking 3 or 4 full cycles to dry clothes took the back off i see no burn ups or anything else but did see where one of thermostats housings apears to be open a lil
Make sure the dryer exhaust hose is not plugged, if there is a flap door on the outside of the house make sure it is free and opens when the dryer is working. The exhaust should be no longer than 15 feet to work efficiantly. each 90 degree bend counts as 2.5 2 bends equals 5 ft of. That leaves 10 feet for the exhaust to be fead to the outside. A plugged exhaust hose is usually the problem when the heat is in the dryer but it takes 3 or 4 cycles to dry. good luck.
Sep 26, 2010 | Dryers
I have a kenmore 70 series gas dryer. the dryer works pretty normal except the clothes take a little while longer to dry and they all smell badly of natural gas. i opened it up and and i can see the...
Check the vent hose for kinks . Also check the exhaust at the outside to make sure it has good air flow to the outside . A dryer either heats or not . Due to it heats , the only possible problem is vent hose blockage .
Sep 23, 2010 | Kenmore Dryers
Kenmore Elite 73942 Gas Dryer only runs with start button held
Unplug the dryer. Open the control console.Mark and remove the wires from the start switch.
Using a volt meter set for continuity,touch meter leads to R1 and R2 while pushing the switch. No reading is a bad switch.
Touch meter leads to R2 and CT1. No reading is a bad switch.
If the switch checks out good the start windings in the motor are bad.
Dec 27, 2009 | Kenmore 73952 Gas Dryer
My Kenmore dryer keeps cutting off
Vacuum all of the air passages including the hose to the outside vent. Remove the lint filter and wash it in hot water and detergent; rinse and replace after drying. Restricted air flow may be tripping an over-temp switch.
Oct 12, 2009 | Dryers
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
Frigidaire FGQ1442ES Gas Dryer Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
