Question about Toshiba Satellite A45-S250 Notebook
Toshiba satellite a45-s250 bios password removal
Unit powes on and shows password=
  • bigc3po Mar 11, 2009
    WHICH FUNCTION KEY DO YOU PRESS TO INTER THE BIOS SETUP SO I CAN BOOT FROM CD
  • 20 Answers
Try this man:
first: download hiren's boot cd Second: burn it using nero third: boot it at hiren's boot cd fourth: after booting from the hirens bootcd choose bios/cmos fifth: use bios! sixth: browse for any passwaord there, but do not use the blaster, it can cause system failure, i think the admin password for a45-s250 is ami..
hope this helps you
Posted on Mar 26, 2010
I have bios problem.update my bios but it work very bad.i can't select cd boot therefor i don't install windows.plz guide me
Posted on Mar 21, 2009
    Scholar:
  • 77 Answers
Give this a try:
You can do it the hardware "way" where you have to open your laptop and remove a battery inside the computer or can do it the software "way"..
I would recommend you the software if you doesn't have tried to open a laptop before..
Download this and burn the image to cd and boot from it:
http://www.pccmos.com/download/PCCMOSCleaner.iso
Further instructions: http://www.pccmos.com/guide.html
PS: Please rate this solution
Posted on Mar 11, 2009
  • Veli Kerim Celik
    Veli Kerim Celik Mar 11, 2009
    Its very different from computer to computer, but just try all the f-keys (f1-f12) or the esc or delete key..
  • Veli Kerim Celik
    Veli Kerim Celik Mar 12, 2009
    I changes from computer to computer so try esc, f1, f2, f6, f10, f12 or delete..
Driver toshiba satellite a45-s250 wireless network connector
Toshiba Support > Satellite A45-S250 Notebook PC > Atheros 802.11 a/b/g WiFi driver with Cisco WPA support for Windows XP and 2000,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=555703&rpn=PSA40U&modelFilter=A45-S250&selCategory=2756709&selFamily=1073768663
HOWEVER, it requires the Atheros Client Utility v2.4.2.18, to be installed. If it isn't installed on the laptop, this utility needs to be installed first. Then the Driver above.
If you need guidance in downloading, or installing please post in a Comment.
Regards,
joecoolvette
Oct 08, 2011 | Toshiba Satellite A45-S250 Notebook
How to reset bios password on the toshiba a45 s250
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Jan 12, 2011 | Toshiba Satellite A45-S250 Notebook
The right hinge on my screen is broken. Can it be
Here's a link to hinge repair procedures...
http://www.laptopka.com/2007/08/01/replacing-satellite-a45-broken-hinges/
It also has a link to search for the replacement part you may need.
Jan 01, 2010 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S130 boot failure
* If it's a BIOS problem, try this :
1. Shutdown ur system, and remove the BIOS battery.
2. Reinstall it and start again.
3. You can also replace the battery. (if above steps don't works!)
4. Try to get a updated version of BIOS driver. (if above steps don't works!)
* If u r also hearing any kind of beep sounds, it may be bad RAM (memory). Try this :
1. Shutdown ur system, and remove the RAM.
tell me if these steps don't work! :)
Dec 31, 2009 | Toshiba Satellite A45-S250 Notebook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S250 PC - where is the ram located?
The memory is under the keyboard on these models. Remove the plastic piece with the power button, and you will see the screws for the keyboard. Don't forget to rate me (fixya). thanks
Jul 31, 2008 | Toshiba Satellite A45-S250 Notebook
Manual
There's only one guide that I could find for the A45. It should help, depending on how far you have the machine torn down.
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
Bios
To enter the BIOS, press the Esc key when the Toshiba script shows up on the display. You should then get a message to press the F1 key to continue. Press the F1 key and you should be in the BIOS. The Boot sequence is on Page 2 of the Bios settings on many Toshibas. To get to page 2 press the page down key. Make sure you follow the screen prompts because your system may be slightly different.
Please rate this, thanks
Jun 25, 2008 | Toshiba Satellite A45-S250 Notebook
Password on toshiba notebook
Please visit this website as it has some methods for getting by or cracking that password protection:
http://www.tech-faq.com/reset-bios-password.shtml
Good luck and let me know if these methods work!
May 14, 2008 | Kogi L7CH Monitor
Toshiba Satellite A45-S250 Notebook Logo
630 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
