Question about Copystar CS-1510 Copier
Cs-1510 makes loud high pitch noise when copying
Would this be the toner motor or the laser unit? Where can you get parts at a reasonable price?
  • 27 Answers
Loud noise is usually coming from the laser unit. if you can ger to it, lubricate it's polygon motor shaft with some oil. It usually works fine afterwards. It is a bit of a hassle to remove the laser unit.
Posted on Mar 18, 2009
Dyson high pitch noise
Dear Tasha ,
I suggest that you clean out the tubes and see if any paper has been rolled into the bottom. P.S. Do you know how tall 170 cm is in feet.
Feb 25, 2014 | Vacuums
Where can I get a drum for a copystar cs1510?
http://www.digitalsystemcopiers.com/Copystar_CS-1510specs.html
About Us How to Order
Warranty
Contact Us
Email
CopyStar CS-1510 Digital Copier
CopyStar CS-1510 Digital Copier Supply Prices Toner Type Cartridge: Price: $37 Yield:7000 Developer $54.00 per 100,000 copies Drum $107 per 100,000 copies
CopyStar CS-1510 Digital Copier Optional Equipment
Oct 22, 2011 | Office Equipment & Supplies
Machine makes a loud siren like noise when started up or making copies
This is the polygon engine (laser writing system) which is weary
Contact your service department to replace it, or wait until it fails ...
May 12, 2011 | Copystar CS-1510 Copier
Where do I find parts for CS-1510, specifically a laser unit
there are no parts available that i am aware of. when i have a laser unit go out on a machine that i service, i send it in to have it rebuilt. quite pricey however.
razors
Mar 03, 2011 | Copystar CS-1510 Copier
New toner installed, toner still registered as low
Throw in nearest skip and buy a Kyocera printer!!
Jul 07, 2009 | Copystar CS-1510 Copier
I think its a problem with the cyan (blue) toner...when i print a colour document the printer works but makes a very stranhge (high-ish pitch) noise and the colour which should come out green comes out a...
The Cyan toner cartridge is jammed, it needs to be taken out and try and move the white plastic gear round a bit to free it. It normally is very stiff and wont move much, but if you can move it a fraction that will do. One thing, did you overfill the cartridge with toner? sometimes that will cause them to seize up.
Delboy
Jan 25, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
Copystar CS-1510 Copier Logo
108 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
