Question about AT&T CL2909 1-Line Corded Phone
Att cl2909 locked up - AT&T CL2909 1-Line Corded Phone
How do I increase number of rings on CL2909 ATT phone
The CL2909 does not have an answering system. Thus the number of rings will depend on the caller's patience or your voice mail service. You need to check with your telephone provider to find the procedure to change the number of rings before your voice mail system answers the call. You'll have to get into the voice mail system and then access those options.
AT&T has the manual for the CL2909 on the product page: https://telephones.att.com/pd/290/CL2909-Speakerphone-with-caller-ID-call-waiting . The direct link to the manual is currently https://cdn-media-att.vtp-media.com/products/CL/CL2909/CL2909_CIB_i14.0_20170210.pdf .
I hope this helps. If you add a comment with your telephone provider, I may be able to find a guide to their voice mail system settings.
Jul 26, 2017 | Lands Phones
Why is there no dial tone?
Try a different wire from phone to wall. "in use" means that the phone senses an "open" line.
Oct 22, 2015 | AT&T CL2909 1-Line Corded Phone
Display shows line in use after installing batteries but phone is not plugged into wall
Phones show "in use" when the line voltage is low because another set is off-hook, which also happens when the line is unplugged. In other words, that is normal.
What happens when you do plug in the line? If it still shows in use then, the jack might be wired with reversed polarity. Try it elsewhere - someone else's house/office where the phones work "normally" to see what it does.
Feb 11, 2015 | AT&T ATT Speakerphone CL2909
I need att manual for cl2909
http://cdn-media-att.vtp-media.com/media/p/document2/products/%7B5A9D7833-E5B1-4913-BB01-23BF5B1FE914%7D/CL2909_UM_11_Final.pdf
Aug 22, 2014 | AT&T ATT Speakerphone CL2909
My att phone has been locked by att how can i get it unlocked
Contact AT&T by dialing 611 from an AT&T serviced phone.
Nov 20, 2013 | Computers & Internet
Remove child lock on model PF3230 on a ATT remote system
you are going to need the original remote and the lock code.
Dec 05, 2012 | Apex Digital Televison & Video
I can't figure out how to set up a voicemail or answering machine
The phone doesn't have an answering system built-in. If you use a voicemail service, you will need to check with the provider for the phone number and then follow their directions to set up your mailbox. If you are connecting a stand-alone answering machine, you will need to daisy chain the devices. Connect the phone cord from the wall jack to the answering machine IN port. Then use another phone cord from the answering machine OUT to the CL2909 TEL port. (If you are using a fax modem (or regular modem), with an anwering machine feature on your computer, then you still want to use this chain method. The data port may not let the computer answer a voice call.)
If you are using a free standing answering machine, after connecting everything together, make sure that you hear a dial tone and can properly make calls. If you do not get a dial tone, replace cables. (I recommend you check that the phone works by plugging it directly to the wall jack before doing a daisy chain of devices.) Turn on the answering machine and set the outgoing message and number of rings as per the directions for the answering machine.
If you have any problems, make sure that the line is good. I use an old rotary phone to check my service connection (at the box since that has RJ-11 connections in my home). You may want your phone company to check if the line is good to your home if the service doesn't have RJ-11 connections. If the problem is in the wiring, check the jacks (loose wire/broken wire) and exposed wiring (missing insulation/breaks). You may need a professional to check in the walls; your telephone service provider will fix this for a fee. If the problem is outside, then the provider will fix it free.
You can get the manual and guick start guide as PDF files from AT&T: http://telephones.att.com/att/index.cfm/product-detail/?ProductID=290 . The links are on the right hand side of the page.
I hope this helps.
Feb 07, 2011 | AT&T CL2909 1-Line Corded Phone
I purchased a sim card from tmobile to replace my att simcard on my samsung SGH-A707.The new sim card won't work,it sy's incorrect sim and networt lock.
Hello
The sim wont work because it is locked to the att network which means it will only work with att sim cards.
You will have to unlock the phone from the att network before it can work with the T mobile sim card
You should contact your network provider so as to get steps to unlocking your phone from the att network or you should contact a repairer to help you unlock it
Thank you for visiting fixya
Mar 10, 2010 | Samsung SYNC SGH-A707 Cellular Phone
My ATT sim card locked on my sidekick and it wont unlock
Go to att.com log in to your account and under phone devices there is a link to obtain a puk code but it has to be entered using Att phone. That was how I unlocked my sim card.
Sep 02, 2008 | T-Mobile Sidekick II
AT&T CL2909 1-Line Corded Phone Logo
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
