Question about IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 no power
My IBM Thinkpad T30 does not power up. With AC adapter only unit shows no power, with AC adapter and battery together unit gives a green light for a few seconds and then battery light goes orange and stays orange. Power supply gets hot and battery is warm, my thought is the adapter may be bad can anyone offer a solution?
  • shuang888 Aug 23, 2008
    I experienced the exact the same problem. I then changed another good AC adapter, no change. So I wonder if the power unit within the thinkpad is bad.
  • Anonymous Oct 11, 2008
    I'm having the same problem. What's different though is that I know My battery's life out. Need to have it re-packed. My problem though is that I encounter this problem after getting on the internet. Any suggestions??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
I agree with you and have a link for adapters http://www.google.com/products?q=IBM+ThinkPad+T30+2366+adapter&hl=en&rls=com.microsoft:en-us&um=1&sa=X&oi=froogle&ct=title
Posted on Aug 02, 2007
SOURCE:
Can a nx9110 charger /ac adapter work on an ibm thinkpad t30
Thefollowing three conditions should be met for you to use a charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop. Pleasecheck carefully before using nx9110 adapter on t30.
Dec 11, 2010 | IBM ThinkPad T30 2366 Notebook
The t30 light goes immediately from green to orange and won't power up. I just replaced the fan
Remove all power sources(battery and AC adapter) from the laptop. With the power source out, press and hold down the power button for 15 seconds. Then, power on the laptop using the AC adapter only. If this does not work, issue might have something to do with the motherboard.
Jun 09, 2010 | IBM ThinkPad T30 2366 Notebook
My ibm thinkpad t30 screen is very dark when i start it up and it wont allow me to see it well
Sounds like you are losing your backlight inverter. It sits under the bottom of the screen and is responsible for converting the DC power of the battery and power adapter to high voltage AC for the backlight in the lcd panel.
May 19, 2010 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.Some time it boot up and run but then it won't do it nextime after it been power off. Battery for BIOS is good, Main...
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | IBM ThinkPad T30 2366 Notebook
Battery light yellow won't come
allow battery to complete charge (green lite)
Or change battery if chrge not completing.
(check your AC charger)
Jan 11, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad no power with ac power adapter but works with battery
If prior to this it works intermittently with the AC adapter, it means the connection from the adapter power unit to the motherboard was lost and this is a typical problem with the Thinkpad. It needs a re-soldering job and not something that one can do without a proper repair manual on how to open the laptop. Try googling your problem and find out if someone has the same experience and managed to resolder by him/herself.
Oct 18, 2008 | IBM ThinkPad T41 Notebook
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30
Try starting without the battery, and cheking the memory chips.
Jul 04, 2008 | IBM ThinkPad T30 2366 Notebook
IBM does not work
Try memory or replace system board
Mar 24, 2008 | IBM ThinkPad T30 2366 Notebook
Ac adapter problem
Buy a new T30 adapter off ebay, they are cheap enough and you could probably get OEM if you know where to look.
Mar 10, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
854 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
