Question about Garmin GPS
Replace internal battery Garmin gps 12xl
How to replace internal battery
5 Suggested Answers
  • 5 Answers
SOURCE: Memory Battery Died in my
Wildstreak, same happened to my GPSMAP 180. Its old and no longer supported by Garmin. I did call them and they gave me the model and number of the battery (mine is a Panasonic) Also advised that units are heat sealed so I am taking mine to a local electdronics shop that also sells Garmin and have them replace the battery.
Seadrive Joe
Posted on Aug 29, 2008
SOURCE: need to replace memor4y battery
I have the same problem. how can I get it fixed?
Posted on Oct 11, 2008
SOURCE: What sort of internal memory battery is in my garmin 12xl?
You can find the battery here:
http://www.mouser.com/Search/Refine.aspx?Keyword=658-VL1220-1VC
To open the case, scrape the sealant in the grove around the unit; then use a flat screwdriver, as wide as possible, that fits in the grove. Place the screwdriver on all sides and different places. Rotate the screwdriver gently until the glue tears and both gps housings can be separated.
To replace the battery you will need to be handy in soldering in tight spaces.
Posted on Mar 30, 2009
  • 1514 Answers
SOURCE: WHAT TYPE OF INTERNAL BATTERY GOES IN THE GARMIN
It takes 4 x AA batteries
Posted on Sep 08, 2010
My Garmin GPS 12 XL will not power up. Is that an internal battery problem or is the unit shot as Garmin technicians tell me?
try swapping out the batteries, no harm in opening it up with a screw driver (will void the "warranty" that expired 12 years ago) check if there is an internal battery (usually a coin cell battery like cr 2025 or CR2020) otherwise it is dead and time to get an e-trex 30... great simple little unit with lots more features
Jul 09, 2014 | Garmin GPS 12XL GPS Receiver
Lcd damage garmin 12XL
You really posted a help question for this. Replace the screen obviously
Mar 01, 2014 | Garmin 12XL GPS Portable/Handheld GPS...
When i open garmin 12xl it gev me vois when i press page bottom this message show me (Memory Battery is Low ) how to solve this
The memory battery is a BTR2032 or a CR2032. This is one of those coin type batteries. To replace it you need to open the case and depending on when your unit was made you will either find a battery hold or the battery will have wires soldered to it.
The batteries are cheap. Usually under $1. Getting someone to change might cost a bit. If this battery goes out then your unit will forget settings and so on and have to reload everything from scratch every time you use it. It will work fine but might take 5-10 minutes (depends on how many sattilites it can see) to get running.
Oct 10, 2010 | Garmin GPS 12XL GPS Receiver
My garmin 12 xl will not turn on under battery power. it works with the power cord
check it out manual regarding battery hours and if it is damaged try to replace under warranty options with out error
Dec 14, 2009 | Garmin GPS 12XL GPS Receiver
Lost destination after saving it
Sounds like the internal memory battery is run down - it's charged from the AA's. Usually does not recover. Battery (the VL1220) is shown here: http://www.panasonic.com/industrial/battery/oem/chem/lith/vana.htm.
It' easily replaced once the case is open but requires a steady hand with a fine tip soldering iron. Local story started by me here.
Sealing the case up again is very fiddly - hard to make a tidy job with silicone.
Feb 22, 2009 | Garmin GPS 12XL GPS Receiver
Garmin etrex screen too dim to read
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
Sep 22, 2008 | Garmin eTrex GPS Receiver
Memory Battery Died in my Garmin GPS 12XL...Can I replace it?
Seadrive Joe
Aug 29, 2008 | Garmin GPS
Garmin gps 95xl battery
The battery is a Panasonic VL1220. See my local post here about replacement.
Aug 12, 2008 | Garmin GPS 12XL GPS Receiver
Mar 24, 2008 | Garmin GPS 12XL GPS Receiver
GPS Logo
42 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
