Question about Saws
Need to purchase replacement part for a wts200l rigid tile saw
The arm which holds the motor stationary over the tray had snapped and I cannot find ANY replacement parts for this saw on Rigid.com
  • Phil Rivera May 11, 2010
    What is the model number?
TILE SAW WTS2000L ;THE UNIVERSAL GUIDE CATALOG NUMBER #:6006001.I NEED TO BUY ONE
Posted on Apr 12, 2009
  • NewClassic Sep 03, 2010
    The Ridigid WTS2000L Tile saw is actually built by Chervron North America and not directly supported by Ridgid. You can reach them at 866-974-3443. This is a direct line for WTS2000L service.
    The Supporting Arm cost $55.48 with 2nd day delivery.
Does the rigid wts2000l tile saw power supply cord have a fuse in it
NO
the fuse will be in the breaker.
the cord could be broken internally or at the plug or motor
Jan 27, 2017 | Saws
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
I have a tile saw and the tray needs repaired due to small holes that have developed on the underside of the tray/pan from loading and unloading over time
If it is not a structural issue just clean the area and caulk it or even with some construction adhesive. Fibre glassing it may be an alternative.
Sep 15, 2014 | Saws
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
How to replace wiper motor
Ads
  • 61f78f0c26a3e415aa6619b36d476c945e92bb99.jpg?&w=295&h=250
View Slide Show
Answer:It his very easy to remove the motor/wiper assembly so do not hesitate to do so:
Remove the plastic covers off the wiper arm retaining nuts.
Remove the wiper arm nuts with a 13mm socket.
Twist and pull with your finger tips and finger nails at the base of the small rubber squirt tubing off the hard plastic squirt delivery tubes.
You may have to yard up and down on the wiper arms pretty hard to get them loose from their tapered shafts. Don't be a mindless gorilla but be brave and keep at it. They will come loose.
Remove the cowl cover by pulling or prying out the center of the six retaining push pins. Then lift the cowl cover up then out at a 45 degree angle. You will find the cover is a very tight fit between the right hand wiper shaft and the weatherstrip at the base of the windshield. Be brave and keep pulling and prying until it comes loose.
Reinstalling the cowl cover and getting the rubber weather strip over the cover is the hardest part of the whole job. Use putty knifes (slowly and carefully!) or a very small slender screwdriver. It took me half an hour just to do this part of the job that. ugh.
Remove the 3 bolts holding the wiper assembly.
Disconnect the electrical connector by squeezing the retaining tab that you cant see on the backside of the connector. You have to squeeze real hard.
Lift the wiper assembly out.
If the wipers are standing straight up when turned off then keep reading:
The parking pawl probably has a broken spring and is not working correctly. The pawl is a 1.25" long piece of metal external to the motor and is part of the Stack-O-Plates on the output shaft of the motor and to which the wiper push rods are attached. When you turn the wipers to "Off" the motor will reverse direction and the pawl will catch on a stationary tab that is part of the motor/wiper frame. This will hold the wipers in the down position while the motor continues to run and allow the parking Stack-O-Plates-Spring-Wrapped gizmo to do its magic which drags the wiper arms down into the extra low "parked" position. If the tiny spring that holds the pawl in the out position breaks then the pawl will not engage the stationary tab. The wipers will then continue swinging upward through half a swing at which point a cam/switch that is internal to the pulse board (the cover on the motor output gear (three T20 Torx screws to remove) will tell the motor to stop because it thinks the parking Stack-O-Plates gizmo has finished doing its job but instead the wiper arms will be stuck in the "Hello, I'm a dork" raised flag position.
WARNING: Use caution while working around the wiper mechanism. If the key is on and the wiper lever is set to "Intermediate" then the motor can start unexpectedly. If your fingers are down there in the wrong place, the mechanism has more than enough power to break bones and/or peal the skin right off of them. Don't be afraid, just be deliberate and methodical and always be aware if the motor/electronics are energized.
Remove the Stack-O-Plates assembly from the motor output shaft (T30 Torx) to access the pawl to put on a spring. I wrapped one and a half loops of spring around one protrusion on the end of the pawl and around one tab of the stationary clip that limits the swing of the pawl to hold it in the "swung out" position. The loop of spring applies very light pressure but that is all it needs. This will all make sense when you are looking at the pawl mechanism. I cut off one and a half loops from a spring like what you would find in a retractable ball point pen but bigger. Use what spring you can find even if it from a ball point pen. When the motor runs in the forward direction the pawl harmlessly swings out of the way as it passes by the stationary tab. Bend the stationary tab in or out as necessary so the pawl engages straight on to it. I will try and post pictures of all this. hope this helps, I copied off the internet for you
Before remounting the whole Stack-O-Plates gizmo assembly you will need to set the motor into the correctly timed position. Plug the motor in, then turn the wipers to "Intermediate". When the motor stops then turn off the ignition switch or quickly disconnect the motor. The motor is now in the correct position. Remount the Stack-O-Plates so there is about 1/4" to 1" space between the pawl and the stationary tab. Tighten down the T30 Torx bolt (blue lock tight recommended) then test the unit to see if the pawl engages to the stationary tab and lets the parking Stack-O-Plates do all its parking gyrations before you remount the whole wiper assembly. When you are all done try not to wear out the wipers by constantly turning them on and off for the next few hours of driving just so you can marvel at your handy work. :O)
Buy the way, if you turn the wipers off and they just wiggle a little bit while the motor goes click-click-click-click trying to do its parking thing then you need to alter (slightly) the relationship between the cam/switch arm inside the pulse module (again, the cover on the motor output gear, three T20 Torx screws to remove). There are two switch/contact arms in the center of the pulse board. The one closest to the board that engages the plastic cam mounted to the board is the one you want to change slightly. The other free floating arm is driven by the cam on the big motor output gear and is the contact to let the electronics know the output gear has rotated half a turn and the wipers are now parked. I bent the one arm closest to the pulse board away from its cam just slightly so that only about 3/4 of the "hook" on the end of the arm (you will know what I mean when you look at it) is hitting the ramp on the cam (the cam spins clockwise). Verify that the electrical contact actually opens a bit when the arm is riding on the high part of the cam. You may have to adjust and verify a number of times to find that sweet spot where it runs reliably. It took me half an hour of fiddling. O_0
Apr 16, 2013 | 1999 Pontiac Sunfire
Saws Logo
1,849 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
