Question about U-Line Wine Captain (2015WC) Wine Cooler
ULine UL-2767-S How to replace thermostat
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Oct 06, 2009 | U-Line 75WC Wine Cooler
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Nov 01, 2008 | U-Line 75WC Wine Cooler
Unit not working
could be a thermostat problem, check the thermostat for continuity. it should have, if not, then replace the thermostat.
tnx 4 using fixya,
drcool
Oct 01, 2008 | U-Line 75WC Wine Cooler
BI-95 ULINE
raritan eng/whirlpool ice maker assembly
Jun 20, 2008 | U-Line Icemaker
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
56 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
