Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Lacie Hard drive problem
My computer sees the drive and i am able to access some files in the drive associated with some programs (e.g itunes). however when i try yo explore the drive i am not able to see any file in that drive. i have tried defrag and disk repair. any help you can give would be greatly appreciated
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
This model appears to have a high failure rate in consumer reviews, so it may have physical damage on the disk. Only a re-format of the drive will isolate bad sectors that won't hold data. I don't know if you're using a PC or Mac, but try re-mounting your drive after a fresh re-boot of your computer. If the drive came with the manufacture's software to allow it to communicate with your computer, then try removing this software from your system and re-installing it again. This will repair a corrupt driver or I/O program. If that doesn't work, try using the drive with a new or different firewire cable. Other users have reported this drive working again after replacing the cable. If you use Mac OS 10.2, you might not be able to initialize or partition the hard drive. This may require you to partition and format the drive on a different computer.
Posted on Aug 02, 2007
SOURCE:
I do I access previous saved files from my external Maxtor hard drive?
When you hook up a USB drive, it appears as a removable drive in "My Computer", clicking on that drive will open it up to you to see the files. clicking on specific files will allow you to see them if they are associated with a specific program, and most of them will be.
Jan 01, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Missing files after using the recover CD
In this case try some data recovery program to see if it can help rescue your data on your external.
May 31, 2010 | LaCie (300728U) 250 GB Hard Drive
Trying to drag all files from itunes into lacie 250 g design by porsche hard drive and it won't let me.
Thank you for asking your question with FixYa Support.
I am not sure what type of computer you have that your LaCie is connected to, but first and foremost, make sure the external hard drive has been properly formatted to work with the operating system your computer has.
For Windows computers: the LaCie should be formatted in either FAT32 or NTFS (recommended- more secure).
How to Format a HD in Windows Vista
For Mac computers: the LaCie should be formatted in Mac OS Extended (Journaled) format.
How to format an external hard drive in Mac OS X
If your LaCie is already formatted, then the best way to import your entire iTunes library from the internal hard drive of your computer into the LaCie, especially if you are unable to drag and drop the library into you LaCie, is to try a simple copy and pasting of the ENTIRE iTunes folder from its home on your computer to the LaCie hard drive.
You can also use the website I like to reference which provides some good alternatives to effectively migrating your iTunes Library from a PC or Mac to your external hard drive:
Here is that support link:
How to Transfer iTunes Library to another Computer
(also included in this article, are external hard drives)
For sake of space, I want you to review this article, because I not only agree with its content, it is exactly what I would explain to you as well in a more condensed, easy to follow fashion.
I hope I have helped guide you well on your question.
Regards,
-Mactechtrainer
Mar 28, 2010 | Computers & Internet
Lacie ext hard drive, 500 GB, doesn't show files but 123GB used
you can always recover your files with the program undelete . exe
verry good working tool.
if you are interested
Feb 13, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Will erasing my LaCie ext HD impact any files on my Mac Book?
It will only effect thoes stores on the external harddrive. You will have to check the contents of the LaCie drive and see if it has any files you typically access from your Mac Book. Other then that no it will not effect files stored on your Mac Books drive.
Jan 06, 2010 | LaCie (300728U) 250 GB Hard Drive
My LaCie was working great and suddenly I can't access the files. Windows Vista tells me the drive needs to be formatted. Did it crash? Can I recover the files using a recovery program?
I have recently completely recoverd two lost partitions using Paragon Partition Manager 10.0. I was very impressed with the program. The option find lost partitions is under Partitons - Advanced.
Oct 31, 2009 | LaCie (301015) 120 GB Hard Drive
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
I can not access my external drive,
Shut down the PC, unplug power to the drive for 30 min. Plug power back in and start the PC back up.
Hope that helps...
Geno
Apr 02, 2008 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Lacie sounds like its working , but i can't find the icon on computer
Your hard dive is probably not formatted. You can check if your external hard drive is detected by the BIOS during bootup. You can also check this by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your lacie. If you dont then the drive is probably not detected. If you see, you can just partition it from here and it will appear in your my computer.
Dec 24, 2007 | LaCie (301015) 120 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
77 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
