Question about Philips Televison & Video
Philip/Magnavox tv will not come on
My 12 yr old Philips Magnavox 32'' CRT TV Model TS3254 C102 does notpower up no more. There is no power at all, no green light, no sound,no picture. It doesn't do a thing when trying to turn it on.
What can I check inside of this unit to determine the problem.
5 Suggested Answers
SOURCE: black screen no sound
Look at this
Phillips/Maganavox TS3258 Dead, HOT shorted R&R Flyback, HOT
Transistor,#3610- 22k, #6328 SMD diode, #7325 SMD Transistor and Check
#3611/3608 190 ohm resistor by #3610
TELEVISION MAGNAVOX TS3258 Flyback Bad Replace fly -
R3610,22K-R3331,47K(SMD)-D6328(SMD)-Q7325(SMD)-IC7150
TELEVISION MAGNAVOX TS3258C101 DEAD Shorted flyback, will also damage
IC7150, R3610, R3331, D6328, and Q7325.
Posted on Nov 13, 2007
  • 61 Answers
SOURCE: TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Posted on Mar 05, 2008
nileshsingh2
  • 246 Answers
SOURCE: no sound, no picture. tried unplugging and
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Posted on Oct 25, 2009
SOURCE: Is there any sort of
No, there is no fuse, it's all circuit board and fuseable links.
Posted on Jan 07, 2011
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox TS3254 C102
I would suspect on this model which is not projection but a 32 inch crt type set---broken or bad solder connections first and second something triggering the shutdown (latch) circuit it uses.
Someone would have to be able to open it safely and remove board and look for around the high voltage transformer cracked or poor connections---instant shutdown would almost always be a short of some type but if it runs f o r a few minutes a bad connection is more likely---even one.
Oct 23, 2012 | Televison & Video
No sound, no picture. tried unplugging and plugging back in...same problem. the green power light just keeps blinking 14 times over and over again. tv is around 11 yrs old...philips magnavox 32" smart...
Oct 25, 2009 | Philips Magnavox TS3260C 32" TV
Magnavox projection tv model 8P6044 C102 is very
The CRT fluid is cloudy and should be replaced. Goto www.TvRepairKits.com. They have a kit to do it yourself.
Ed
Jun 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
What is the Chassis # for this model?
Hi
the chassis number is located at the back cover of Tv, and to PCB.
Thanks!
May 29, 2008 | Philips Magnavox MS3252S 32" TV
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Televison & Video Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
