Eiki eip-25 lamp won't start - Office Equipment & Supplies
5 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Eiki EIP-25 shuts down after 30 sec (ceiling mounted)
there must be something loose inside. maybe the button panel.
Posted on Nov 18, 2009
projdoc
  • 2237 Answers
SOURCE: I thought my light went out on my Eiki projector,
if there are no leds on the top, replace the power supply. if the leds are on and the fans are running, it may be the colorwheel or the ballast.
Posted on Jan 06, 2010
SOURCE: No power to Eiki EIP-2500 projector
Look for buldging capacitors, or capacitors with black on the tops of them (like they got hot). Bad caps have left me dead in the water. Also look at all of your transistors (the ones with 3 prongs at the bottome (emitter collector base) look to see if some of them look burt or melted. Some transistors will have only 2 connected or maybe even one clipped off. Power transistors commonly have a screw at the top and screw into a "heat sink" or an aluminum block to help with heat. Hands down.... capacitors 9 out of 10 times have left me dead in the water. Heads up, capacitor manufactuers are manufacturing caps so that it's hard to see when the go bad, (buldge or blacken at the top). Looks like the old meausure voltage in parrallel and amperage in series will have to apply for these fixes. Get a schematic, change caps, check fuses for continuity. on my Eiki EIP-200 i notice a little buldging on C727 on my main power board (the board withthe Giant capacitor on it). Anything hot looking or burn marks, usually a replacment part is in store.
Posted on May 12, 2012
SOURCE: i have an EIKI EIP-5000 it starts normally but a
This happened to me. In the projector, the section in between where the lamps go, there are two very small switch type levers, when a new lamp is positioned, these switches are supposed to move in line with a 4mm section of the new lamp. If they are not aligned together with the switch and slotted into place, it appears as if the projector doesn't recognise the new lamps. Unscrew the lamps again, make sure these little switches are aligned (a very small screw driver could help while positioning) when refitting the the lamps. Screw the lamps tightly and fire up. Hope this helps.
Posted on Jun 17, 2012
I need to reset the lamp life timer on my projector, but it requires a password. We never set a password. Is there any way around this?
From the manual: " User name and password are not set in the factory " . Don't enter anything.
Manual for the projector here:
http://www.projector-manual.com/manuals/eiki/EIKI_EIP-4500_DLP.pdf
Jul 22, 2014 | Eiki EIP-4500 DLP Projector Multimedia...
Light stay on
possibly max lamp usage hours have been exceeded
Jan 29, 2014 | Eiki Office Equipment & Supplies
How to reset lamp timer for EIP-X200 EIKI? Thanks.
this model has a firmware issue, an update is necessary to get the lamp timer reset option. This is a expert job, you need the right image file and DLP composer software V4.2 Lite.
Aug 31, 2011 | Eiki EIPX200 2000 ANSI Lumens DLP Video...
Eiki EIP 1600T projector will not power on. Projector was running when power went off for just a few seconds. Will not power back up now. I have power to projector.
inside there is a thermal fuse, that might be activated, because the cooling of the lamp did not happen after the power surge.
You need to remove the upper cabinet to reach, but do this very carefully !!
May 22, 2011 | Eiki EIP-1600T DLP Projector
I have both the stand by and lamp indicators flashing then the lamp liight goes to a red The lamp never actually lights up in this time.The globe has only done about 250 hrs.
The bearing of the colourwheel is locked. No rotation of colourwheel possible, then also no lamp ignition. Colourwheel has to be replaced.
Nov 06, 2010 | Eiki EIP-2500 Multimedia Projector
I have an EIKI EIP-5000 it starts normally but a minutes later it stops working and the temp light turns on. also the screen has some displaced pixels like when a video card is broken. also this...
Nov 03, 2010 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
The lamp will stop all of a sudden. If we wait long enough, it will come up again. It was hard to get the lamp to start originally.
You have a ventilation issue, probably a clogged filter or a faulty fan. The projector shuts down when it gets too hot or things it may damage the bulb by doing so.
May 07, 2010 | Eiki EIP-200 SVGA DLP Projector Multimedia...
Hold down power
lamp close to expiring. or the colorwheel is not starting up.
Sep 24, 2009 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
Mar 07, 2009 | Eiki LC-X50M Projector
35 people viewed this question
jasbo
jasbo
