Question about Frigidaire Electric Dryer
E62 code frigidaire dryer - Frigidaire Electric Dryer
2 Suggested Answers
I have a code e62 on my dryer
did some research might be a faulty heater or some kind faulty wiring or some kind of circuit board failer. i checked on youtube where i guy talks about errors and he explains them too. Tumble Dryer Error Codes E61 E62 E63 E64 E65 E66 E67 Electrolux AEG Zanussi so try watching this video this help you on what you can do more for your dryer..
Jun 23, 2017 | Computers & Internet
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
I have a Frigidaire Affinity front load washer ATF6000ES. The lights on the control board go on and off on their own and it beeps at the same time. I've tried resetting it but have the same result. When I...
Thank you for your inquiry, Steve Lesko!
I understand that your Frigidaire washer is displaying an error code of "E62" and the lights on your panel go on and off with a beeping sound. I do not show "E62" as a valid code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your range. You can do that by disconnecting the power from it for roughly ten minutes. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or other error codes? With this information I can better address the issue at hand. In the meantime, I suggest resetting your washer. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E62". I look forward to assisting you. -Matt
Jan 30, 2015 | Frigidaire Washing Machines
Code e62 on frigidaire gallery series model GLTF2940FS2
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire GLTF2940F Front Load Washer
Electrolux dryer error code e62
Good Afternoon Friend,
I understand you are receiving an E62 error code on your Electrolux dryer, model# EIED55H. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Electrolux EIED55H Dryer
E62
Good Morning John, thank you for your post!
I see that your Frigidaire washer is continuously beeping and displaying error code E62. However, I show that the correct error code is EB2. Typically, EB2 indicates that the incoming line voltage is above 130VAC. Please verify that the power supply is correct. You may also disconnect the power to your washer for up to ten minutes by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, it would be advisable to contact a professional the since the main control board is possibly faulty.
May 23, 2014 | Frigidaire ATF6000ES Front Load Washer
E62 code on display
E62 - Power relay to heater unit faulty
Could be:
  • Heater unit faulty.
  • Wiring faulty.
  • Electronic board faulty.
At this fault appliance forced cooling cycle.
Dado
Mar 11, 2014 | AEG T57800 Electric Dryer
Frigidaire FEQB4000FS1 keeps beeping; error code seems to be 62 but cannot find what the 62 leads to :(
Good Afternoon Jennie, I am happy to assist you!
Typically, an E62 error code is an indication of a short circuit. Let's try resetting the dryer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the dryer on. If resetting the power does not correct the issue, your appliance could be experiencing a potential heater relay failure, control board issue or wiring problem. I would suggest contacting an experienced service technician to determine the precise cause.
Best regards!
Oct 19, 2013 | Frigidaire Electric Dryer
Frigidaire  Electric Dryer Logo
80 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
