I WANT TO LOCATE THE POWER PIN ON THE MOTHER BOARD
  • 167 Answers
Hi, ok be careful, if you look at the pins in a cluster most times on the right side of motherboard,(if in the tower) they should be marked,rst,pwr,hdled,pled,very small print.get magnifying glass so you can read it better.pwr is what you are looking for. sometimes it may be 2 pins next to each other, or separated by one or two pins. little white lines usually isolate them visually. hope this helps,reply if you need further help.
Posted on Mar 11, 2009
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
HP G61 no power
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Need to connect power, speakers and drives to mother board
Locate the pin connection in the motherboard symbol spkr and SCSCI panel connector. Be sure to connect it well.
Mar 17, 2010 | Dell (E210882) Motherboard
WHERE TO PUT HARD DISK POWER PIN IN MOTHER BOARD
The hard disk power cable is to be connected to the power cables that comes from the SMBS. And only the data cable is plugged on to the Mother board
Mar 11, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Pc will not boot. power is into the power switch as it lights up when pressed to turn on computer. with the case off the fan to the power supply and fan on the processor turn for approx 3 seconds then...
check the pin assign ments on Mother board. verify that reset and power pin plugged properly,
or
*********** board circuit is touching to metal or a metal part of your cabinet.
or
clean the mother board with dry air blower so if somthing laid on mother it will be blown out.
Nov 17, 2008 | Computers & Internet
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Connecting Speaker
Dear Big Timmo,
To connect the Speaker Pins u have to check left or right side of u r mother board where u r power wire, reset wire and Hard disk led wire connected to the mother board. it has 12 or 13 male pins. There u will find in writen speaker in the motherboard. I hope now u can connect u r speaker pins..
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845GERG2 Motherboard
Computer shuts down y by itself
remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
Computers & Internet Logo
236 people viewed this question
David Payne
David Payne
