Question about Uniden 2.4GHz Expandable Cordless Phone System with Selectable Ring Tones - Black/Silver DCT746-2
Uniden 2.4Ghz Cordless Phone (Both handsets) show out of range.
I just bought the uniden 2.4ghz cordless handset w/base and 1 extension. So, 2 handsets, 1 base, 1 remote charger. When I plug in the units, they say out-of-range. I need help to get it working. Could you pls. provide assistance asap. Thanks!
5 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
Posted on May 10, 2008
SOURCE: Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Posted on Oct 03, 2008
  • 82 Answers
SOURCE: Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Posted on Oct 14, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
Can i add 3rd handset to uniden xs 1455+1 cordless phone
if you can get the exact model as the existing hand set it should not be a problem
just follow the installation process to get the base to recognize it so that it connects
Dec 05, 2015 | Uniden Cordless Phone
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    I have three handset cordless phone only the main base phone work the other two says connecting when you turn it on but it wont connect it have loss its connection with the base phone
    Often the handsets must be re-registered when they won't work. Sometimes they have to be de-registered, then re-registered before getting them to work. Uniden has many different model number 5.8 GHz cordless phones, send a comment with the model number and I will give specific help on your cordless. I have included a link where Uniden cordless manuals can be downloaded if you need it.
    http://www.uniden.com/index/manuals_results.cfm?cat=1
    Mar 27, 2011 | Uniden 5.8GHz Cordless Phone
    I have uniden cordless phone model dxa15588-2, how do I register handset on base?
    1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
    2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
    3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
    4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
    5-Make sure your phone is working again after "Registration Complete" shows on the display
    Hope this will Help. Thank you for using Fixya !!!
    Nov 17, 2010 | Uniden Cordless Phone
    My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
    With the phone in standby, press MENU/SELECT on the base.
    Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
    On the handset, press and hold # until the handset beeps and displays Handset Registering.
    When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
    If the display shows Registration failed, repeat the process again.
    Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
    Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
    ADDING HANDSET SAYS OUT OF RANGE
    A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
    1. Remove battery
    2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
    3. Screen will be blank. Immediately press the right soft menu button.
    4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
    5. Remove battery (yes again)
    6. Reinsert battery (this time there's no need to hold down any buttons)
    7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
    8. Place handset on base and it will register as normal
    Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
    My handset reads "out of range" but it is sitting on the base.
    It could be faulty phones or try replacing the batteries
    Jan 10, 2009 | Uniden Cordless Phone
    May 03, 2008 | Uniden Cordless Phone
    Uniden 5.8Ghz phone.
    Jan 20, 2008 | Uniden Cordless Phone
    Lands Phones Logo
    51 people viewed this question
    Top Uniden Lands Phones Experts
    Dave Ellis
    k24674
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
