Question about Goodman CKL36AR36 Air Conditioner
Central air fan is running slow and will not start without help
This fall notice the fan not running in the central air unit so. Turned it by hand and it started but ran slow
    Genius:
  • Goodman Master
  • 1,363 Answers
Try a new capacitor
Posted on Aug 12, 2015
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: AC Fan outside running slow
The brown wire goes to the capacitor. It probably shorted out with the nicked wire. Replace the capacitor.
Posted on Jun 29, 2009
  • 534 Answers
SOURCE: central air blowing warm air
2 things could be happening. 1, inside unit needs filter changed and coil cleaned. 2, unit is low on freon. A/C tech should be able to check for both. You can check the a/c coil to clean it yourself but to check for low freon this will have to be done by a a/c tech due to the complexity of the system. the ice is caused by a series of things however, check the a/c filter and the coil located behind the filter. this coil should be free of any debris. if you have indoor pets sometimes the hair clogs the coil causing the freeze up.. To clean the coil you need to get a small weed killing sprayer.. At the a/c supply house you can purchase cleaning solution that is easy to use an safe for the enviroment also leaves your house smelling great. if the coil inside has been cleaned check to see if the coil outside is clean if not you can clean it with a water hose by spraying the coils out. MAKE SURE TO KILL THE POWER beforehand. Also spry the water onto the coils only and spray in the oppisite direction of air flow. Have system checked by a/c tech if you do not feel comfortable doing any of these suggestions
Posted on Jul 16, 2009
SOURCE: Condenser fan running backwards on heat pump
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
Posted on Jan 14, 2010
  • 10 Answers
SOURCE: I need help with a buzzing sound in my air conditioner.
It is probably the compressor humming. They can make some funny noises especially on start for a while. If the unit is not cooling it may be the start capacitor or the comressor may be locked up.
Posted on Jul 19, 2010
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Central air conditoner outside unit
Well, the answer is yes. I have seen a bad capacitor cause a fan motor to run backwards. BUT..... After replacing the capacitor and WIRING it up the right way, everything should be fine. A lot of aftermarket condenser fan motors are reversible, so it can run counter-clockwise (CCW) or clock-wise (CW). However, most factory fan motors come one directional and on your specific unit, the air should always push out of the top. Running the unit with the fan going backwards will actually some-what do it's job, but damage other components like the compressor because it runs at higher operating pressures than what it is designed for.
Have someone else look at it! That's going to be the best advice I can give you. If they can prove that a capacitor caused the motor to permanently run backwards..... I want to know! Hope this helps and good luck with your unit.
Jun 22, 2012 | Heating & Cooling
When i turn my central air on the fan not running so do the motor and i don't know why. i have this goodman central air for four year now.
I had the same problem with the fan not running and the compressor hard starsting. It turned ouot to be just needing a new capacitor. I also bought a "hard start" unit to hook to the new capacitor to ease the burden of the starting in case there is low voltage to the unit during high usage times. The very first thing I would check would be the capacitor. Don't fool with this yourself unless you first discharge the capacitor, as this is very dangerous unless discharged first.
Jun 02, 2011 | Goodman CKL42AR42 Air Conditioner
My outside fan will not run and the inside unit runs constantly. can't push the reset button on unit outside
Your out door unit fan motor not runs due to pressure not build up at Heat mode. If its cool mode only fan runs with compressor when thermostat calls for it.
Without having technical knowledge, don't press any reset button. Hope it's helpful?
Dec 09, 2010 | Ruud Central System Air Conditioner
I have a 1979 general electric central air unit that the compressor runs but the coolant fan won't come on. The fan turns freely by hand. Any tips? The model number is BTN924A100A3
It could be a bad motor or capacitor. It also might not be getting any power. If it uses a head pressure switch or a condensor temp control to slow the fan on cooler days, it could be that also.
Jul 08, 2010 | GE Heating & Cooling
A/c compressor blows electrical breaker
could be a bad run capacitor or, the motor is bad. have the capacitor checked that would be the cheapest thing only about five bucks
Apr 11, 2010 | Heating & Cooling
Central air unit runs but no cold air from the start. after a while coil freezes up solid.
Maybe dirty air filter or slow fan motor or if the ice build-up does not cover whole of coil it maybe short of gas due to minor leak.
Jul 27, 2009 | Heating & Cooling
I have a GE central air conditioner model
If you are talking about the indoor fan it is probably a bad capacitor. Replace the fan motor capacitor. And YES, if the fan motor needs replacing too, you can DO-IT-YOURSELF.
Jul 05, 2009 | General Electric Heating & Cooling
Jun 29, 2009 | Goodman CKL36AR36 Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
62 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
