Question about Bower XUUNI Wizard Universal Camera Battery Charger - Memory Cards &
How to use the Bower XUUNI Universal Battery Charger?
How do I charger flat battery
with a battery charger.
There are lots of different universal battery chargers for camera's. Just google for a universal battery charger for camera and then the brand an model.
Mar 09, 2015 | Cameras
Charging instructions
The instructions on how to insert the camera battery and charge in the Inov8 universal charger are available in this youtube video
Inov8 Universal battery charger
The inov8 charger for panasonic battery should be similar to use. You have to align the pins of the battery with the charger terminals and connect the mains plug. If you have the 12v travel kit then connect to the car lighter socket.
Aug 05, 2014 | Inov8 Digital Battery Charger for...
Can you use a Universal battery charger
You may use any battery charger that's compatible with the EN-EL10 battery used by the S570.
Apr 28, 2012 | Cameras
Hi. i have a sony dsc w130 and it says use only with compactable battery only. i know why that, coz i charfhe it with a universal charger. i heve tried short circuit, and nothing happends. i bought a new...
It is important for you to know that the specified charger that it is supposed to work with has a special method of charging it as the battery is a very delicate one. That is why it is specified that you have to use a compatible charger.
When you use a universal charger, it does not charge the battery as the battery is supposed to be charged. This inflicts some minor damage on the battery and makes it impossible for the battery to work.
The compatible charger has a unique spontaneous way of emitting charges into the battery and the universal charger lacks this. So when the universal charger is used, it does not emit the right amount of charge into the battery.
The only way around this is if you can modify the charger or the battery in such a way that it might work. But then, you maybe damaging your camera. Instead, buy a specified charger.
Hope this was helpful? Please comment for more information and thank you for using fixya.
Jan 24, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
How can i charge my Vivitar 550 camcorder without original charger? (Currently in remote part of Afghanistan)
Look for a ,,Universal Battery Charger" like those ,,made in China" remove your battery pack from camcorder, and insert them in the charger. The charger is inexpensive and very useful, having two adjustable flexible contacts that fits to every possible battery used in cellphones, cameras and camcorders.In my country Romania, this universal charger cost about 5 dollars or 4 Euros.
Sep 09, 2010 | Vivitar DVR-550 DV Camcorder
Vivitar universal battery charger
http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=vivitar+universal+battery+charger&_sacat=See-All-Categories
If wanted to purchase a vivitar universal battery charger, you can check above link with ebay. Hope this helps you.
Thank you.
Aug 10, 2010 | Cameras
I have a pentex optio m60 it was okey but suddenly it saying battery depleted could me please tell me what is the solution for that and why does it happen
There could be a couple reasons for this:
1. When you have the battery in the charger, does it indicate that the battery is dead or fully charged. I would suggest placing the battery in a universal charger to check to see what the rating is on the battery, a universal charger will indicate the true power left. If the universal charger shows the battery is drained but your charger says it's full, you have a bad charger. If they both indicate full but camera says dead, you have either a power supply issue in the camera or the main board cannot read how much life is actually left in the battery. If your charger says full and the universal says empty, your battery is malfunctioning.
2. Does the camera turn off when it says battery depleted or does it simply keep telling that it's depleted. If the unit doesn't shut off, you have a firmware issue that needs technical repair on. That specific model does not allow you to download updates via USB from your computer, you need to send it to Pentax for repair.
Dec 08, 2009 | Pentax Optio M60 Digital Camera
Computer not charging with universal adapter
hi i had the problem before , you have to buy dell charger in order to charge your battery, universal charger doesnot work with this, the only way not to lose your power is to keep the charger connected, in this way the battery will not be charged but u will not lose the power. again you need dell charger the universal only gives power but doesnot charge.
Best Regards
Mar 23, 2009 | Televison & Video
Battery pack
If you want guaranteed performance, use original parts only!
Jerry G.
Dec 29, 2007 | Bower (724AFN) for Nikon Flash
Bower XUUNI Wizard Universal Camera Battery Charger - Memory Cards & Logo
513 people viewed this question
Top Bower Video Cameras Experts
Are you a Bower Video Camera Expert? Answer questions, earn points and help others
