Question about Asko Dishwashers
Asko spray arm
Spray arm falling off, keep putting it back on
  • 12 Answers
SOURCE: third level spray arm
If your dishwasher is the same as our GLD2440REB1, the sort of star-shaped piece on the ceiling unscrews.  Then there's a sort of flangey washery kind of guy that you can poke through the star-shaped piece and snap into the arm.  Then screw the whole thing back on to the pipe.  I know this works, because I do it every time the arm falls off.  Which is every time I run the dishwasher.  ... Oh, crud.
Before I order a new part (spotted for US$7.65 plus shipping), I'm going to try putting some thread or a pin or something in there to hold it together.  Maybe some epoxy.
Am I a cheapskate or what?  :-)
Posted on May 31, 2008
SABM
SOURCE: frigiaire dishwasher upper spray arm cover came
Okay, it worked! Reach up in the very top (inside) of dishwasher and unscrew the only thing up there that will unscrew. I just used my dishrag (remember righty-tighty and lefty-loosey). Mine had a small white ring laying in the indention that had 2 "teeth" pointing down. I turned the 2 white teeth crosswise to the two gray teeth in the top of my spray arm and it snapped right together. I then screwed the whole thing (with spray arm attached) back to the top of the dishwasher. I didn't have to worry about the above 'one tooth at a time' thing because mine only had 2 'teeth' and snapped back on easily. Yes, it's a little wobbly but it's always been that way. I always try to make sure nothing is hitting it but will be more careful. Good luck with yours. :)
Posted on Apr 16, 2009
  • 9 Answers
SOURCE: dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
Posted on May 19, 2009
SOURCE: Frigidaire dishwasher PLD2850RDC2
i DON'T KNOW IF THIS IS A SOLUTION OR NOT. My DW (same make and model) came off after being knocked off with an overly tall dish load. But, in addition, the 'nipple' gasket (looks like the nipple for a baby bottle, pretty much) was broken. I attahced it several times, same problem. I am going to replace the gasket. I think it might be the necessary part to fix the issue.
Posted on Dec 29, 2009
  • 56 Answers
SOURCE: upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Posted on Feb 08, 2010
Testimonial: "Wish one could buy just the clip and not the whole assembly, but it is not expensive."
Upper arm of HJA 8362 keeps falling off. Could there be a part missing/broken?
yes - the clip that holds the arm on is probably broken off or weak. Order a new spray arm and spray arm support tube - a new wash basket will probably come with these parts on - but check first as some don't.
Jan 31, 2018 | Dishwashers
Mod m.d.c.5100aww ser28126829ax I had a repairman come out. He said the "sprayers" are plugged. I'm on a fixed income. With my bills I can't afford to get it fixed. Trying to fix it myself. I...
Most dishwashers dispense the detergent via gravity and the sprayer arms spraying against the soap dispenser once the little door flips open during the wash cycle. Since it sounds like the soap door is opening I would look at the sprayer arms and make sure they are free of food particles or other debris that might be keeping them from rotating and spraying properly. Here are some instructions for performing this check.
Remove the lower dishrack from the unit. Reach into your dishwasher and spin the lower spray arm. Take note of whether or not the arm moves freely or if its movement is restricted. It should not be restricted in its path of motion. Now gently pull up on an end of the spray arm. The spray arm should be free to wobble up and down. Unscrew the arm retaining knob (some of these are left hand threads) and take the arm out for inspection and carefully examine the spray arm seams. If they have split or are damaged, the dishes may not receive the amount of water pressure required to fully clean the dishes or to rotate the arm properly. What’s more, if water is in fact spraying out of the spray arm from its seams, it is possible that it can cause your dishwasher to leak. Make sure there is no debris in any of the holes.
If your dishwasher has a spray tower, pull up on it as far as it will go and then let it fall back down. Again, this movement should not be restricted. It should be a fluid and smooth motion. Also, unscrew the spray tower and examine it for any debris or foreign objects. Remove any that you find.
Gain access to the upper spray arm by removing the upper dishrack. Perform the same tests for the upper spray arm as you just did for the lower spray arm. Keep in mind that the upper spray arm may not wobble as much as the lower spray arm.
On a final note, some dishwasher models have a water tube that meets up with the upper spray arm once the upper dishrack is pushed back. It is a good idea to check to make sure this tube is aligning properly with the upper spray arm and that this has not split or is damaged in any other way.
Mar 24, 2008 | Dishwashers
The upper spray arm keeps falling off during the wash cycle. It seems to click firmly into place when put back. Is there a problem somewhere else in the machine?
Make & model would be really helpful... but without that... I'd guess you have an OBSTRUCTION that the "spay arm" is conflicting with...
Check the clearances of all the contents with your moving parts...
or try emptying your machine. Trying it in that configuration.
Failing that... replace the arm.
Search Over 2 1 Million Appliance Parts
Parts Select Appliance Parts and Repair Help
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Aug 13, 2016 | Dishwashers
Asko dishwasher top wash arm washes. The bottom wash are does not more.
More often than not on Asko dishwasher the lower spray arm or filter will clog up causing this issue. The filter in the bottom twist out for you to clean. Check the lower spray arm holes they to will come clogged causing this issue.
Appliance & Refrigeration Repair
Mar 24, 2011 | Dishwashers
Our Asko dishwasher no longer cleans the top shelf of dishes properly. Fine white and black grit is left on the dishes after every wash, and if there is any food residue on the dishes it does not come off....
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Check also that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 04, 2011 | Asko 24 in. D3350 Dishwasher
Water pumps into the bottom of the dw but the spray arm doesn't rotate and spray. It also empties, so the problem seems to be with the spray arm. Any solutions?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 04, 2010 | Asko 1385 Dishwasher
I have a asko washer W6021 that will not spin. Pump works but no spin
That problem can have many and varied solutions...I have tried to put together in this tip the most common and easiest to checkout problems. For many of the spray arm problems the solution will be here, but it would be impossible to cover every possible problem in any answer with out actually being able to hands-on disgnose the problem....
Dishwasher2_bing.gif Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Jun 23, 2010 | Asko 1385 Dishwasher
Upper spray arm falls off during operation, even after snapping
Feb 04, 2010 | Frigidaire Professional Series 24 in....
GE dishwasher arm keeps falling off. what is the
you should replace 3 parts in diagram,these are the upper spray are,the bearing,and the holding screw the #s are AP3191593/AP3794248/AP3425295 they coincide with the above parts and are all G.E. part numbers
Sep 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwashers Logo
75 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
