Question about Kenmore Dryers
Belt replacement on kenmore 80 dryer - Kenmore Dryers
TheMobilian
  • 8220 Answers
SOURCE: Where is my belt on my kenmore dryer model
The belt goes around the drum 1b15519.jpgThe part number being 341241 on the common Kenmore dryer.
409d816.jpg110ef8a.jpg899f2ef.jpg19a8834.gifoil them rollers and idler. Old school training manual
MORE
Posted on Jun 29, 2010
AlmostBob
  • 550 Answers
SOURCE: Kenmore Series 80 Dryer.
No need for a schematic, there are two kenmore dryer belts, 'full size' or 'apartment size', if it is a belt you will be able to here the motor racing unloaded, turn heat to cold before testing, dont want to blow a thermal fuse.
Kenmore dryer comes apart from the front,
  • UNPLUG dryer 220V is not fun
  • remove the lint screen
  • remove the screws under the lint screen holding the case top to the screen holder
  • with a putty knife or other blunt blade release the catches at the front corners of the top and raise top
  • remove screws holding front of case on, from inside the dryer
  • remove door switch cables
  • lift front of case off and set aside,
  • can reach motor, belt, felts and rollers.
  • broken belt will be obvious, lying on the floor
If belt is broken, examine rollers and felt bearings for wear, stuck rollers or no felt left, is the most common cause of belts breaking, extra tension is required to spin the drum, If damaged replace them, they are cheap and easy to do, and it woud be no fun if another belt broke quickly
reasemble after repair in reverse order.
Posted on Aug 25, 2008
erpaalai
  • 999 Answers
SOURCE: how do i get to the drum belt on an 80 series kenmore dryer
You do the belt from the front. It involves removing the top so the front can come off to get the belt around the drum. eric
Posted on Jun 11, 2009
jsrock516
  • 5911 Answers
SOURCE: i have my kenmore 80 series dryer apart, and i am
Kenmore dryers are configured in several different ways as far as the location and routing of the dryer belt. For drawings of how the belt is configured on your dryer, go to Repairclinic.com and click on the "Repair Help" link. On the following page locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to the Kenmore section and refer to diagrams H, B, or K. If you are not certain, please post back with your complete model number (located on a nameplate around the door opening) and I can determine for you. I hope this helps you.
Posted on Oct 23, 2009
hunter19_46m
  • 7482 Answers
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Posted on Nov 16, 2009
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
Kenmore 80 series dryer banging
Yes you need to replace the tumbler guiding wheels .should do that soon so you don't ruin the motor and belt
May 03, 2014 | Dryers
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Kenmore series 80 dryer . Drum does not spin, even when empty.
Good day,
If runs and heats, then the most probable cause is a broken belt.
Not hard to change. Below is a tutorial on how.
The Kenmore line is manufactured by Whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Dec 19, 2009 | Kenmore Dryers
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
Dec 15, 2009 | Dryers
How do i access and adjust the belts on a Kenmore Series 80 dryer
I dont think there is an adjustment, it will need a new belt and maybe a new belt belt tensioner. If the belt you have now is slipping I would replace with a new, then go from there.
Oct 26, 2009 | Kenmore Dryers
I have my kenmore 80 series dryer apart, and i am replacing the belt. having trouble configuring the belt around the pulley and motor, since the belt cannot actually go into the pulley, its sealed. help.
Oct 23, 2009 | Kenmore 62622 Electric Dryer
Need diagram for belt replacement
can i please see a diagram dryer so kenmore 80 series belt assemble
Jul 02, 2009 | Kenmore 73952 Gas Dryer
How do you replace a broken belt on the Kenmore 80 series dryer?
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 20, 2009 | Kenmore Dryers
Dryers Logo
128 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
