Question about Icom BD-680 Multi Region Free DVD 3D/2D Blu-ray Player FOR 110-220 VOLTS
Need to update icom bd-680 dvd player
I need to update the software in Icom BD-680 DVD player, what website do I go to to download the update?
  • 17 Answers
SOURCE: getting started with the ICOM IC_R5
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Posted on Feb 02, 2009
  • 17 Answers
SOURCE: Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
to do this....
To set the step....
To scan...
Thats it!
M3ODQ
rjrod888
  • 8 Answers
SOURCE: If you where going to Buy one radio which one would you Buy?
I am a marine electronics technician with 28 years experience. I have also been a licensed amateur radio operator for the past 12 years. Based on my professional experience with both brands (Icom and Yaesu), I have to advise you to go with one of the Icom units. The Yaesu is a good radio, but Icom's customer support is far superior. I have had no problems dealing with their service department over the years, something I can't say about Yaesu.
Hope this helps.
Posted on May 02, 2009
  • 42 Answers
SOURCE: How to program an Icom IC-R5 handheld scanner
to store a fcy press BAND to go to your fcy range ie 118.000 airband
dial your fcy ie 127.900(shanwick ocean area control) press and hold V/M for 1 sec, small numbers now blink, dial the memory slot you wish to store into ie 001 then press V/M again for 1sec and this will store 127.900 into mem slot 001. make a list:-
mem number / fcy / mode(am - fm) / station / bank
to prog a fcy into a "bank", press V/M for 1sec - blinking mem numbers - dial mem number ie 001(127.900) press MODE - "bank" flashes past-
-- -- -- -- 001 shows, turn dial to show A-00 this is the first "bank", pressing BAND scrolls through all the alpha "banks" - choose one.. ie A-00 (for airband..) press V/M this puts mem 001 into "bank" A mem slot 00, there are 100 slots in each letter 00 to 99. do this to any fcy you want to scan as a group.
to scan a bank press V/M - small numbers appear -
press BAND to scroll through any "banks" you have created ie A B C D etc (only banks with fcys in will display), press MODE -"bank"- press MODE again and you will start scanning just that "bank" of mem slots.
MODE starts and stops the scan... each letter holds 100 mem slots.. happy scanning!!!
Posted on Sep 28, 2009
jeffreyclay
SOURCE: ICOM IC-28H very low sound from radio even thought volume is max
I had a very similar problem on a hand held scanner. In my case the mylar speaker cone had separated from the voice coil. I found an exact replacement for under $4 at Allied Electronics.
Posted on Feb 16, 2010
My dvd player says it needs an update to play my movie, how do i do this?????
Goto Samsung website,goto Blu-Ray software update sections,have all the instructions.Most like just down load the update solfware to a flash drive and up load to update ur Blu-Ray player.
Jan 01, 2011 | Samsung BD-P2550 Blu-Ray Player
I want to update my sharp bd hp17 blu ray player, would you please told me where I can get the update?
i went to sharp website and downloaded updates to a flash drive. then put flash drive in back of player in usb port. it will download.
Nov 20, 2010 | Sharp BD-HP17U Blu-Ray Player
Toy Story 3 will not play on my Blue Ray player all other blue ray disk's work fine.
Have you updated your Blu-Ray player recently? All BD players need to be updated from time to time because of the growing technology of Blu-Ray. Its always been a con of BD players. Best thing to do is have your player connect to the internet.
I hope this is the back of your player. Connect your Cat5 (Ethernet cable) to your BD player and than to your router or modem. The port should look like this on the back of your player.
Once you have this connected start your player and it will have a option in the menu to update. Once the update is complete Toy Story 3 and all new BD discs should work. If not, its possible that the disc is bad. More often you just need to update the player.
Nov 03, 2010 | LG Super Blu BH200 Blu-ray and HD-DVD...
I am seeking software update for my BD-HP210U Blu-Ray Player.
You should have an option in the menu which says Update Firmware, failing that the Sharp website will have the update which can be burnt to disc and inserted into your player.
May 30, 2010 | Sharp BD-HP21U Blu-Ray Player
I have a BD-HP16 Sharp Aquous Pure Mode DVD
I solved this issue by downloading the firmware update and installing it into the Blu-Ray player. Follow the instructions in the manual. It seem to work for me. Go to sharp usa website, download updates.
May 02, 2010 | Sharp AQUOS Blu-ray Disc Player
Is firmware available to make this Samsung BD-P1400 player easier and faster?
Check Samsungs website for firmware updates which will also update the BD compatibility for playing new encryption discs
Mar 15, 2010 | Samsung BD-P1400 Blu-Ray Player
HOW DO I DOWNLOAD SOFTWARE UPDATE FOR BD HP-20U?
You (if you are in N.America) need to go here: http://www.sharp.ca/downloads/default2.asp
Then read the the owners manual , page 45 and 46.
Nov 06, 2009 | Sharp BDHP20U Blu-Ray Player
I have a Samsung BD-P1000 Blu-Ray Disc Player that will not play Blu-Ray discs rented from BlockBusters in Calgary, Alberta, Canada. To Date, of all my 100 regular DVD, and approximately 25 owned Blu-Ray...
BD-P1000 Update Solution
The solution that worked for me: I went to www.samsung.com/ca and downloaded the Samsung BD-P1000 player's firmware update to my desktop. When opened, I was directed to"burn" a DVD on my computer. I then inserted the new DVD in my Blu-Ray player. The player automatically checked and confirmed player model number and registration and uploaded information from the DVD and the update was complete. The BD-P1000 then flawlessly played the rented Blu-Ray disc of "The Scorpion King".
Thank You Samsung!
Nov 27, 2008 | Samsung Televison & Video
Blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Nov 22, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Icom BD-680 Multi Region Free DVD 3D/2D Blu-ray Player FOR 110-220 VOLTS Logo
73 people viewed this question
Top Icom Televison & Video Experts
Are you an Icom Televison and Video Expert? Answer questions, earn points and help others
