Question about Korg SP-250
3 keys are stuck and wont depress brand new out of box
XP-10 lost sound on some keys
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 26, 2016 | Roland Music
Amp won't turn on.
If its new out of the box then don't open it take it back to the seller. Its under warranty.
Apr 05, 2014 | Peavey IPR-3000 Power Amp
All c keys and all f sharp keys no sound when depressed.
The key scanning matrix cable/circuitry has lost two of the connections. Could be either a loose cable or worst case a cracked circuit board under the keys.
Aug 26, 2011 | Yamaha P85 88Key Portable Digital Piano
Numark CD DJ IN A BOX w/2-NDX200s/M1a/HEADPHN - NUCDDJINABOX ONE OF THE CD WONT EJECT
Was it working at first, and it just stopped? Try unhooking everything and just isolate the one cdj and plug it in see if it will eject. If its Brand New and this just started happening my sugguestion is to take it back to the store. you get what you pay for and numarks whole dj in a box line is the bottom line stuff.
Jun 14, 2011 | Numark Industries Numark CD DJ In A Box...
The clamp on the top of the stand that holds the cymbal down is stuck and cannot be screwed off. My cymbal is stuck on the stand, and its extremely difficult to transport now.
Try lubricating it with a penetrating oil such as "Blaster: or other brand available in automobile parts stores. Let the oil penetrate a bit before trying to unscrew it...
Also you can try heating it with a hair dryer to help break it loose.
When finally free, spray some CRC226 periodically on it to keep it free... You can get that at Home Depot in the electrical dept.
Jan 28, 2011 | Pearl C70w Double Braced Cymbal Stand -...
My new barrington 402 tenor saxophone has middle c and b out of tune (flat). Everything else seems to be pretty close. Can you do anything to improve these notes?
Try playing low B and low C up an 8ve by overblowing without the use of the 8ve key. Then quickly switch your fingering to middle B and C. Compare the intonation of the low and middle notes.Then play middle B and using your other hand slightly depress the lowBb key cup. Did the note flatten or sharpen. Try depressing both low B and Bb the same way. You may have to add a longer bumper felt or cut some of the length off the bumper felts of these two keys. Also experiment with the Low C key height. Try the G key height also. On some saxophones the position of the tone holes were miscalculated and there is not enough or too little distance between them. In any case you may have to take the sax to an expert saxophone repairman. Have a look on this site for more info:http://forum.saxontheweb.net/archive/index.php/t-9082.html Use the search function to find more info than the page I recommended.
Nov 18, 2010 | Barrington Model 402 Tenor Saxophone
A few of the flat key get stuck on the right hand. On the lower left a few the sound are loud no matter how soft you try a play. Can this be fixed?
I am sure it can be fixed. Who knows what brand or type of instrument this is...
The stuck keys are probably mechanical sticking. The loud keys are probably dirty key contacts that sense velocity.
Take unit in for servicing.
Jan 25, 2010 | Music
Keys keep breaking off our wk-3000 this start just after we bought it brand new in austboughtrial we brought it back to new zealand and have put in 4 new sets
The "C" key of each octave is the weak point of the key section. This section includes the keys of C, E, G and B. After experiencing key failure, I purchased new key sections and before installing them, I put a small portion of two part epoxy on the weak point. I have not had another failure "yet".
Jerry
Dec 24, 2009 | Casio Music
Notes not holding
The key contacts need cleaned.
Aug 10, 2009 | Casio CTK810 61 Key Keyboard
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Korg SP-250 Logo
50 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
