Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Valves rattle on lawn more under a load 24 hp intec
2 Suggested Answers
  • 454 Answers
SOURCE: Briggs and stratton lawn tractor. misses under load after warm up
check air filter, may be very dirty causing it to run too rich
Posted on Jul 30, 2010
Need valve lash setting
.004 to .006 on both intake and exhaust. Keep in mind it has a compression release on the cam shaft exhaust valve side so if it is to tight it will not allow the exhaust valve to shut and will burn out with time as well as power reduction. Too loose will make it hard to turn the engine over,sounds like a low battery. I have had two of the Intec engines that the stud that the rocker arm pivots on pulled out of the engine head a little at a time and drove me crazy until it finally pulled all the way out. I would adjust on Mon, Wen, Fri .
Mar 12, 2016 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
18.0 Intec OHC lawn tractor, model 247.288820. Why does fuel drain into the oil system?
Your fuel solenoid may not working. I put a fuel shut-off in. Not in use turn off
Aug 17, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kohler courage v twin 22 hp on my Troy built Ztr starts fine but loses power when cutting grass
bad valve seat needs valve job motor is overheating looseing power or under load
Aug 06, 2014 | Garden
I have a briggs & strat 17 hp ohv intec model 311707 on my craftsman lawn m. it was running then with a large puff of smoke it quit. now the starter runs it with no compresion, removed the s p (oi
does the engine when it is turning over sound normal? does the engine have any compression at all or is it just not as much? sounds like a burnt valve
Sep 07, 2012 | Measuring Tools & Sensors
My B&S 18hp Intec engine on my lawn tractor will not start but it will backfire??? Will not run
You may get lucky and have a sheared keyway on the flywheel . Just a lil off can make a big difference on timing.
Jul 28, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My 22 hp kohler engine bogs under a load
You did one? Do a complete valve adjust.
Mar 13, 2012 | Garden
Type of oil to use for my Craftsman 24 hp riding lawn tractor
Hello, if you have a Kohler engine you would use any 10w30 oil, but if it is a Briggs & Stratton you would use SAE HD30 oil. Either can be purchased from your local auto parts store. When you refill be careful to not over fill. Use the dip stick to ensure you have the proper oil level. Over filling will cause the engine to smoke under load or possibly blow out a seal. Good Luck!
If this was helpful, please vote yes. Thank You!!
Apr 09, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Transmission won't engage
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Sep 21, 2008 | Craftsman 24 Hp 48" Deck Yard Tractor
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
