TV set keeps turning off and back on for about a half hour
My 27'' RCA flat screen TV has good picture and sound. It turns itself off and back on sporatically for about a half hour and then stays on. Is this worth fixing?
  • 6,784 Answers
I would keep it. you will have to replace a few components on the power board but, its not very expensive to do so.
Posted on Mar 11, 2009
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
RCA tv when plugged in comes on and right back off
IF THE PICTURE IS TALLER THEN THE NORMAL SIZE IT MAY BE THE VOLTAGE REGULATOR. LETTING THE 130V POWER SUPPLY GO TOO HIGH.
Mar 20, 2009 | RCA 27V514T 27" TV
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
No Picture - Black Screen. Intermittent Sound
I repaired an RCA same model with a very similar symptom. I found bad connections on the printed circuit board at L411 and L 412 (coils) in the horizontal drive circuit. Give the set a good Fonzie ( Happy Days) smack on the side and see if it comes on. LOL. Bad connections are common with that model. It is probably worth fixing and no, lightning didnt do it.
Nov 22, 2007 | RCA TruFlat 27F520T 27" TV
RCA F27442: no picture.
you may have bad solder connection in the horiz.countdown section.
you may also have a GEM Star module bad.
Nov 06, 2007 | RCA F27442 27" TV
Picture goes out, sound stays on
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Loud hum when attempting to turn on my RCA F27628 27"TV
could be that the main b+ filter Capacitor went bad and blew up. Also could have been the horizontal output transistor shorted and the flyback poped. In eather case it would be recommended that you take this set into a repair shop unless your familar with HV circuits in tv sets. Good Luck
Jun 10, 2006 | RCA F27628 27" TV
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
