Question about Goldstar MV-1501 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
My Goldstar microwave stopped working.  It seems to have happened when the underneath light bulb blew out - or maybe the bulb blew out due to the problem.
I heard a click when the bulb blew out and the microwave stopped working.  Could a fuse have blown?  Can I replace the fuse?
The microwave is completely dead, no lights, no display, nothing.
Model #MV1502B
Do you have any idea how to fix this problem?
  • Anonymous May 06, 2009
    Bulb blew out and tripped breaker. I unplugged unit, opened up the unit and did some testing (I am a Electrical/Instrumentation Technician) and discovered that the circuit boardon the display face actually shorted out causing the sparks and causing unit to cease its life.
  • 4 Answers
When that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Posted on Apr 03, 2009
  • VickyandBill Collins
    VickyandBill Collins Nov 24, 2013
    where are the fuses located?
  • mikadot
    mikadot Nov 24, 2013
    undo almost every screw you see and remove the shell of the microwave. You will see the fuse holder near the cord.
Jvm1440I went to change a light bulb, light bulb pulled out of threads. Tried to remove threads without turning power off and shorted something out. Underneath lights and fan will not work. The microwave...
Blew a trace off of the back of the board by it shorting out when the bulb was unscrewed, Either have to find someone to repair the main circuit board or order a new one. But $$$$ always unplug the Microwave to replace the builbs, It doesnt seem like a big deal but I have seen this a lot over the years and it really does some damage to the main PC board.
Oct 06, 2017 | Microwave Ovens
Lights under microwave will not come on
When this happens, a lot of the time, it is because the the old bulb burnt up violently or it was unscrewed with the power still on to the unit and if the wires on the bottom of the bulb were twisted together, it probably blew a trace off of the back of the circuit board that supplies power to te bulbs. So either need to find someone to repair the circuit board or buy a new one if you can put it in, if not, need to call a servicer to replace it. But caution, thay are not cheap!!! Always unplug you microwave BEFORE replacing the bulbs!!!!!
Oct 14, 2017 | Frigidaire FMT148GP Microwave Oven
HOW TO CHALGE LIGHT BULB
disconnect the oven from power supply. If the lamp of your microwave is in the most common location, you will need to open the oven by unscrewing the screws on the rear. You will see the lamp behind the control panel. remove and replace the bulb
Jan 12, 2010 | Goldstar MA-1011 Microwave Oven
Completely stopped working
sounds like you blew the fuse inside
Jun 19, 2009 | Goldstar MV-1526 Microwave Oven
When i plug in the microwave it starts running & will not stop
Sounds like you blew a device on the main board when you didn't unplug it first. The whole main timer board must be replaced to repair the unit. Pricey, sorry!!
Aug 01, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung SMH7178STD microwave fan stopped working
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
Dec 03, 2008 | Samsung SMH7178STD Microwave Oven
Panasonic genius microwave light bulb replacement The bulb on my Microwave model RMC275PD blew and no the microwave won't start, if I replace the bulb will the microwave work again? Thanks Richard
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
Aug 27, 2008 | Whirlpool RMC275PD Microwave Oven
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
My microwave stopped working and I'd like to try and fix it myself. Any suggestions?
Because microwave leakage can be hazardous and high wattage is present, limit your microwave repairs to light bulb changes if the light bulb is easily accessible. For other repairs, call a qualified technician to make repairs on a microwave oven. If it doesn't work and the light doesn't go on, be sure it is receiving power.
Jan 18, 2006 | Goldstar MA-7100 Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
904 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
