Question about IBM Wheelwriter 30 Typewriter
Ribbon does not move during typing and no ink gets on paper.
I installed a new ribbon thinking the old one could have exceeded its life span because the ribbon stayed in one spot. The same problem persisted even with a new ribbon. It appears something popped loose (a plastic piece about 3/4'' in length with 6 small holes). I have not been able to find where the piece fits. The little wheel on bottom right of the cartridge can be rotated manually. The typewriter is handy to have around but not worth spending money for shop repair. Can you help? Is there a phone number I can call for assistance?
  • Dick O Reilly May 11, 2010
    What make and model is it?
    DickyO
  • 125 Answers
Hi:
It appears that the ribbon feed connector has come loose from the ribbon feed motor. On top where the ribbon sits you will see where the ribbon couples to the ribbon feed motor on the right side. Look on the bottom of the ribbon and you will see where the ribbon couples with the ribbon deck feed motor. Directly under that ribbon deck is the ribbon feed motor. It sound like the cable came loose and it just needs to be plugged back into to motor.
Good Luck
Andrew
Posted on Mar 14, 2009
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
Please can you send me a picture of how to install the ribbon in to the Remington Standard No.12 typewriter. Or tell me how to thread the ribbon.
Hi, first of all there is no picture diagram for this and this method am giving you is what has been used to install ribbon on different typewriters.
  • Remove the existing ribbon. Note the path that the ribbon takes as it goes from one spool to the other.
  • Roll the ribbon entirely on to one of the two reels if your replacement ribbon didn't come with a take-up reel. If your new ribbon has a take-up reel, skip this step.
  • Attach the end of the new ribbon to the take-up reel if your new ribbon doesn't already have one. In most cases, there is a sharp arrow shaped piece on the reel. Use that arrow to penetrate the ribbon and make a few winds of ribbon around the take-up reel.
  • Slip the take-up reel on the take-up spindle on the right side of the typewriter. Align any tabs designed to turn the reel to move the ribbon during typing.
  • Feed the ribbon through the path you noted when removing the old ribbon and place the main ribbon on the spindle. Give the take-up reel a few turns to make sure the ribbon moves freely through the typewriter mechanism.
Jan 18, 2011 | Office Equipment & Supplies
How do I install a new ribbon on the smith corona electra 220 typewriter and where can I find a manual for this?
This is a sensitive installation, i will advice you follow and adhere to the installation instruction from the the manual of you unit, you can search for the manual at manualsonline.com.
Take care.
Oct 23, 2010 | Smith Corona Office Equipment & Supplies
Nakajima typewriter model AE830. New ribbon installed. when typing printed letters appear only lightly printed on paper. Any way to adjust?
Check to see if the ribbon is moving, then advance the ribbon manually about 6 inches, the ribbon may be old and they do go bad especially the exposed part. If the ribbon isn't advancing Code peroid, comma or slash will get you out of the overstrike mode.
DickyO
Jun 24, 2010 | Nakajima Office Equipment & Supplies
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Characters fill in intermittently.
This is a common problem with old supplies stored in a humid environment. Try leaving ribbon in an air conditioned environment for a couple of days to see if it helps. Otherwise buy a new sealed ribbon to try. Also push the hammer buy hand and see if it moves in and out freely and quickly. If not, the hammer needs some lubricant and or adjusting.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 30 Typewriter Logo
317 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
