Question about Dolphin Maytronics Advantage
Dolphin spirit pool cleaner wont move - Dolphin Maytronics Advantage
    Top Expert:
  • Dolphin Master
  • 8,686 Answers
Possible bad belts or drive motor
Posted on Nov 23, 2017
XPoolGuy
  • 34 Answers
SOURCE: dolphin pool cleaner won't go up to top of the
Most times when a cleaner won't reach the water level in a pool it is usually due to the internal floats being removed or they are no longer in good condition.
Turn the machine upside down, and remove the bag assembly. Should be foam in the plastic housing, underneath, if not replace.
Posted on Jul 03, 2009
john224
  • 1378 Answers
SOURCE: my dolphin diagnostic cleaner for
If your unit has a fuse it will be on the back side of the power supply. If the light on the power supply switch is on, it will not be the fuse though.
Try turning the cleaner upside down on the deck and connect it as you otherwise would. Power it up and it should go through a self test process that takes about 40 seconds to complete. If it turns the tracks in both direction with and without the impeller turning, it is fine and will likley start working in the pool again.
If not, contact us through www.arrowpools.net and click on the FAQ and then Dolphin cleaner catagory. You can also use the Dolphin Serice button for information about sending it in for repair.
Posted on Jul 04, 2009
john224
  • 1378 Answers
SOURCE: My Dolphin Diagnostic pool cleaner stopped working.
Thank you for posting your question here on Fixya.com.
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 13, 2010
jharwell668
  • 640 Answers
SOURCE: I have a dolphin pool cleaner and it won't sink.
If these automatic pool cleaners will not sink, 9 times out of 10 it is because air is caught in the filter bag. The best solution is to turn the Dolphin upside down under water for a few minutes to remove the air or to machine wash the filter bag.
Posted on Jul 21, 2010
diodeic
  • 1622 Answers
SOURCE: how to change the fuse
All you have to do is to check the plug fuse also open the pool cleaner, you will see a fuses holder in which the fuse is inserted, so use a digital or analog multimeter to check the continuity of the fuse, if it is okay or not.
NOTE
you have to be careful in opening the pool cleaner because it is always difficult to couple back . Hope this help in solving the problem, Take care
Posted on Sep 13, 2010
My Dolphin cleaner is less than 2 years old. It was packed away for winter and I unpacked it and submerged it in the pool but the left side isn't rotating it seems jammed
Hey Lindy,
I assume the right side is moving. In this case one of the bearings to the wheels may have seized up during its time stored away. Most Dolphin cleaners have 5 wheels with bearings, so it could be one or a combination of a few. Dolphin has expanded on their cleaners in the last few days, what model do you have?
Sep 20, 2017 | Dolphin Pool & Spa
Tip
Your Dolphin pool cleaner wont start up...
A common problem, especially with 'newer' Maytronics Dolphin brand pool cleaners is that you put the unit in the pool, or even try to turn it on after a cleaning cycle while it is still in the pool, and to that point it has worked fine. You turn the power supply on and nothing happens. You turn it off and back on and still nothing. You leave it, even over night, same thing. What do you do?
While I cannot tell you why it does this (we have a theory but can not confirm it) what usually works is to follow these steps...
1) Unplug everything. Unplug the power supply from the outlet and the Dolphin from the power supply.
2) Let the whole thing sit a couple of minutes (we want to allow any capacitors to discharge).
3) Be sure the Dolphin is out of the water and sitting upside-down on a level surface (Tracks pointing skyward).
4) Reconnect the Dolphin to the power supply and the power supply to the outlet.
5) With the Dolphin still out of the water, perform a self-test. Simply turn on the Dolphin. Within about 15 seconds it should begin to move. The tracks will spin in both directions with and without the impeller motor running at the same time. It is not unusual for the tracks to rotate at different speeds during this test. The test will last for 30 - 45 seconds or so. If it goes on indefinitely, turn it off and contact us for further direction.
6) Assuming the unit has now worked to this point, you should be able to put it back in the water and it will return to normal operation from this point on.
If it still won't run; it runs a few moments and quits the self-test; or runs continuously, contact us thru the Dolphin service form along the bottom of our home page at www.arrowpools.net.
on Dec 16, 2009 | Dolphin Maytronics Diagnostic Robot...
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
Cleaner wont reverse.will try to climbe out of pool wont reverse. this is a dolphin superkleen.
Contact Maytronics, manufacturer of the Dolphin cleaners, for troubleshooting assistance and referrals to regional service centers directly at www.maytronicsus.com or 1-888-DOLPHIN.
John
May 23, 2011 | Dolphin Maytronics Diagnostic Robot...
My Maytronics Dolphin pool cleaner does not entire pool
Check to make sure that your power supply is in a position that it can reach all sides of the pool. It may be as simple as repositioning your power supply to make it more effective. Also, with these automatic pool cleaners, you need to make sure that the filter is off, because it being on can affect where the cleaner is able to go. Finally, make sure the handle is locked in a diagonal position.
May 30, 2010 | Dolphin Maytronics Diagnostic Robot...
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
Dolphin quit working
See if the Dolphin ingested acorns or leaves which may be clogging the unit.
Aug 09, 2009 | Smartpool Dolphin Robo - Kleen Above...
Dolphin Maytronics  Advantage Logo
366 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
