Question about Sony Cybershot DSC-H3 Digital Camera
DSC H3 file error, remove message
When the camera shows the file error message an image is viewable for moment before the message appears. Can the file error message be remove from the downloaded image files on a PC?
  • 3 Answers
No, put gasoline on your camera and burn it....so that your problem on your camera will be solve..
Posted on May 03, 2009
DCIM folder has got deleted, what do I do ? MY DSC-H20 was infected with viruses, I scannerd it with AVAST and selected the option of deleting the infected files from the system. antivirus apparently...
If all your images are backed up on your computer, just format the media card IN THE CAMERA, and that should re-set everything for you when next you take a photo.
Mar 08, 2017 | Sony Cyber-shot® DSC-H20 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
''Unable to display this image'' error on Pentax Kx
Sounds like some of the spaces on the card are becoming corrupted. How do you download? With the camera and USB cord, card inserted into reader on computer, or card inserted in a separate card reader? When you are finished downloading, do you use the "safely remove hardware" icon at the bottom right of your computer screen or do you just yank out the cord or card thereby causing the corruption?
Feb 11, 2010 | Pentax Kx Body Only Digital Camera
Image Management File Error
everytime i turn it on an error appeared ''Image Management File Erro '' :(
Dec 09, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
Hey i have a sony cybershot and when i put the memory stick in the computer and tried to upload the pics they wouldnt show up and so i put it back in the camera and now it says file error
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Refer:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C387963&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=76702826&stateId=0%200%20180282877
Oct 21, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
File error Sony Cybershot DSC-W120
The LCD screen may display a FILE ERROR message when trying to view a still image on the Camera if the image was rotated, modified and overwritten using editing software on a Computer.
To play images you have taken on the Camera, it is recommended that you do not make any changes to the original image files.
It seems that the images are rotated or modified in the Computer.
Check the link give below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C387963
Aug 31, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
I have a DSC T70. Sometimes i get a message "File Error" for some of the pictures. For these pictures, the file does not show and when printed, the picture is merged with another picture.
The LCD screen of the Camera may display a FILE ERROR message when trying to view a still image on the Camera if the image was rotated, modified and overwritten using editing software on a Computer.
Aug 28, 2009 | Sharp Cameras
File Error now shows in camera for rotated photos from PC.
The camera will not display photos that have been edited by something else. Rotating counts as editing. Just opening a photo and then saving it without doing anything else counts as editing.
Apr 29, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
SONY DSC-H3 File Error after taking pictures
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
if it doesnt help then my friend ur CCD imaging Device is Faulty
pls let me know with the results
Rate me FIXYA if i fixed ur problem
Jan 27, 2009 | Sony Cybershot DSC-H3 Digital Camera
File error
Dear jesusfreak22,
I would try reformatting the memory card and see if that gets rid of the file error message. In the manual for your camera it says that message means that the camera is having a conflict when playing back images processed by a computer or another camera.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 10, 2008 | Sony Cybershot DSC-H3 Digital Camera
Sony Cybershot DSC-H3 Digital Camera Logo
161 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
