Question about Sanyo SR-4910M Compact Refrigerator
Sanyo SR-480 compact refrigerator - Sanyo SR-4910M Compact Refrigerator
Joe_Rex
  • 114 Answers
SOURCE: SR-172W not cooling
MOST CASES ... THEY ARE NOT LOW ON 134A . TO TELL ... YOU NEED ONLY START THE COMPRESSOR AND HOLD YOUR HAND ON THE SMALLEST COPPER-LINE ... IF IT GETS REAL HOT 110-130 DEGRESS YOU HAVE A CHARGE. IF YOU MOVED THIS FRIG. AT ALL LATELY MAKE SURE YOU LET IT STAND UPRIGHT UNPLUGGED !!! FOR EIGHT HOURS. YOU CAN ALSO SPEED THINGS UP BY: HEATING WITH A BLOWDRIER BOTH THE COLD PLATE INSIDE AND THE BOTTOM OF THE COMPRESSOR ... THIS BOILS ANY REFRIGERANT OUT OF THE OIL AND LETS THE OIL RETURN TO THE COMPRESSORS OIL RESEVOIR THAT IS AT THE BOTTOM OF THE COMPRESSOR. THESE SMALL FRIGS ARE GREAT ... BUT FRAGILE TO MOVE AND DEFROST. OIL CAN GET TRAPED IN THE COLD PLATE AND NEDDS TO BE HEATED OUT OF THERE AND SOME UNFORTUNATELY USE METAL OBJECTS TO DE-ICE. A LOW CHARGE WILL NOT FROST THE COLD PLATE (EVAPORATOR)EVENLY AS IT SHOULD. LOW CHARGES (AFTER YOU HAVE DONE THE ABOVE) ... WILL ICE UP IN JUST A SMALL SECTION WERE THE PIPES AND CAP-TUBE GO INTO THE COLD PLATE. THESE DONT LEAK UNLESS SOMEONE TOOK A ICE-PICK OR EQUALLY AS DEVESTATING TOOL TO DEFROPST IT. ONLY WAY TO DEFROST QUICK IS WITH HAIR DRIER ...DO NOT PROP-IT UP IN THERE AND WALK AWAY .. YOU CAN MELT OR WARP INSIDE PLASTIC HOUSING !!!!! THEY ALL NEED MANUAL DEFROSTING THE MINUTE ICE STARTS ACCUMILATING. OR BUY A APPLIANCE GRADE HIGH AMP (10 AMP) PLUG IN TIMMER AND SET TO GO OFF AT 3AM AND COME ON AT 4PM ... ONLY 1 HR. IF THERE IS A VISABLE HOLE IN THE EVAPORATOR COLD PLATE ... IT IS ALUMINUM AND FORGET ABOUT EXOPY KITS TO REPAIR THEY ONLY LAST A YEAR IF THAT. IF YOU CALL TO HAVE IT REPAIRED RIGHT WITH SOLDER ... USUALLY A REPAIR LIKE THAT WILL NOT BE WARRANTIED AND PROBUBLY COST MORE THAN TO BUY A NEW ONE. GOOD LUCK.
Posted on May 07, 2007
docjohn174
  • 943 Answers
SOURCE: Sanyo Eclipse refrigerator (Model# SR-4433S)Has
HI thanks for the question. if theres a puncture in the coils . scrap it way too expensive. sorry.
Posted on Oct 16, 2008
SOURCE: Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Posted on Mar 25, 2009
SOURCE: Sanyo counterhigh refrigerator model SR-4911.
remove shelves and insert keg.
Posted on Feb 03, 2010
  • 534 Answers
SOURCE: what kind of bulb I should use for sanyo
purchase an appliance bulb they are available at any hardware store. Ask an eployee in the appliance department and they will be glad to help
Dave
Posted on Mar 18, 2010
Hi! How do I find Sanyo compact ice storage replacement door? Thanks!
I'm assuming that your asking about a freezer door on a compact refrigerator. parts can be ordered on line @ sears direct, go to link below & enter model # or scroll down page & select refrigerators under, find parts by top product categories - scroll to refrigerator brands found - select Sanyo refrigerator parts - scroll down & select your model - select View all parts in this diagram, some parts will be available others you will have to call phone # provided. when looking @ your parts list there will be a exploded view on left ( to see it better click on view full size) http://www.searspartsdirect.com/partsdirect/brands-products/Sanyo-Parts/Refrigerator-Parts
Aug 18, 2014 | Sanyo SR-4910M Compact Refrigerator
User manuals
google user guide sanyo model sr-290 also the temp setting for 37 deg is 37 deg the numbers on the dial are only for reference you should get a thermometer for accuracy
Dec 01, 2013 | Sanyo SR-290 Compact Refrigerator
I need one shelf for sanyo sr 3660s
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 23, 2011 | Sanyo SR-3660S Compact Refrigerator
What is the wattage requirement for the Sanyo SR 172W?
Although the information is not published by Sanyo I was able to find out that the fridge uses about 90 watts.
Jan 06, 2011 | Sanyo SR-172 Compact Refrigerator
Need a replacement door gasket for compact fridge Sanyo SR1286-1
Here is a link to get exactly that Sanyo SR1286-1 door gasket. It says Panasonic on the page but it fits perfectly. O know, I bought one!
SR1286 1 Sanyo
Jun 03, 2009 | Sanyo SR-4310 Compact Refrigerator
Sanyo SR 3620W countertop height refrigerator repair question
yes it can be repaired but it might cost you more than a new one. check with local refrigeration company on quote before they come.
May 09, 2008 | Sanyo SR-3620 Compact Refrigerator
Apr 03, 2008 | Sanyo SR-366 Compact Refrigerator
Sanyo SR-4910M Compact Refrigerator Logo
41 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
