Question about Graco Nasalclear Aspirator - 1750335
No suction on the nasal aspirator
It has suction when the attachment is off but no sucton when attachment is on and have checked all the openings and they are clear.
I have a kenmore model 116.25512506. The roller is spinning but no suction from the head. The attachments have suction but not the head. How do I remove bottom cover to check for blockage?
Is the suction control plastic ring shut?. If it's wide open you get almost no suction. See picture.
25823072-bhx41vpbxgcw2fhkwng0wody-1-0.jpg If that is closed check the long metal wand. Disconnect from the beater bar head and check the whole length of the wand and look into the beater bar head opening for something plugging it.
Aug 15, 2015 | Kenmore Vacuums
How do I use a bulb syringe nasal aspirator?
Hi! I found this helpful article about bulb syringe nasal aspirator on babycenter.com that should help you with your baby's stuffed nose. I hope it helps and that your baby gets well soon!
http://www.babycenter.com/0_how-to-use-a-bulb-syringe-or-nasal-aspirator-to-clear-a-stuf_482.bc
Nov 13, 2013 | Baby Care
About how much does a regular bulb nasal aspirator weigh? Are they heavy?
About 1 pound, definitely not too heavy. After all it has to be small enough to get into your LO's nostril.
Jan 31, 2013 | Baby Care
What is a nasal aspirator?
It\'s used to remove mucus from a baby\'s nose when it\'s congested. The most common types are simply bulbs that you use to remove the mucus. Others have plastic tubes, one for the infant\'s nose and the other you use to suck the snot out. Don\'t worry none of it gets in your mouth.
Graco nasal aspirator is blowing instead of sucking
at a cold is a good idea to use a solution of 1 teaspoon of table salt per 250 ml of water as a nasal drops instead
Aug 29, 2012 | Graco Nasalclear Aspirator - 1750335
Graco nasal aspirator not working
Mine stopped working while in use. I stuck a small screwdriver into the nozzle with the two black rings. It started working. Hope this helps.
Jun 03, 2011 | Graco Nasalclear Aspirator - 1750335
My battery operated nasal aspirator is not sucking when I press the button. I need help in getting it to work again. I have changed the battery. The music part of this product is working
Chances are you are missing a rubber seal. If you take the clear plastic cup off the bottom of the tip, there should be a ring sealing there. There are also two little black rings on the shaft if you pull the tip off from the handle. But I'll be it's the first one over the cup that's missing.
Apr 26, 2011 | Graco Nasalclear Aspirator - 1750335
I have Hooverr Concept One upright(several yeard
If the motor is running then there is either a blockage causing lack of suction or the impeller on the motor shaft, which generates the suction, is loose or broken. You will need to open the machine up to determine the exact cause.
Best wishes,
Graemevm
Dec 18, 2009 | Video Game Consoles & Games
Sucton motor doesn't come on
If the debris cleared itself, it may have gotten into the vacuum fan assembly and jammed the motor preventing turning. Also, check the vacuum motor brushes and springs for damage. Hope this helps.
Dec 05, 2009 | Lindhaus HEPA 14 HealthCare Pro Bagged...
My DC17 hose has no suction and is constricting
You have a blockage in the wand - take the wand off of the back of the machine, separate the wand from the hose by pushing the red button where the hose is attached to the wand. Hold the wand up in the air and look trough it. If you don't see light coming through the other end you have a blockage in the wand. Take a long object like a stick or a metal hanger and remove the blockage. I am confident that this is where the blockage is but...if you can see through the wand the blockage is in the u-bend, but the hose won't constrict then...remove the u-bend which is attached to the vac at the bottom next to the long gray hose - it is attached to the machine with a plastic screw - turn the plastic screw 45 degrees anti-clockwise and clear the blockage from the u-bend.
Jul 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Graco Nasalclear Aspirator - 1750335 Logo
770 people viewed this question
Top Graco Baby Care Experts
Asuwishshop
Level 1 Expert
Kas S
Kas S
masud
masud
Are you a Graco Baby Care Expert? Answer questions, earn points and help others
