Question about Panasonic Lumix DMC-LZ2 Digital Camera
Switches off whenever I try put it into photo mode
The camera switches on fine, when the dial is set to preview pictures. Then, When the dial is turned to any photo mode (when the lens would usually come out) the camera clicks twice (i think this is the apeture opening and closing), beeps then switches off. If you switch the camera on when the dial is already on any of the take photo modes, it clicks, beeps and switches off. Sometimes it does this little cycle 2 or 3 times before powering off. Its not the batteries, we have tried replacing them. Have tried switching the camera on when the dial is on each setting. All settings turn it back off except preview more - when the lense isnt required. Have tried pressing the take photo button after it powers off - this causes it to click, beep then switch off again. If I am required to take it to pieces, which screws should I remove? I can see 2 screws on each end and 3 on the bottom.
    Genius:
  • 2,985 Answers
This is the lens motor not responding Nothing for you to do there any repair is likely to be expensive Contact Panasonic for further advise a New camera perhaps
Posted on Aug 02, 2007
SOURCE:
WhY photos canon A470? i have a canon powershot A470 camera and there's a problem taking photo.. whenever i take a picture, it's either fully white or have white stripes on the pictures.. i thought it
Perhaps you check the settings. If the camera is on nightshot, or manual, with a long shutter time or wilde open diafragma your pictures are all overblown, or stripes come from lights. Put the camera in automatic. The main dial on the green camera logo, and try again. If this does not work, Please let me know how the settings are on your camera. Success
May 08, 2014 | Canon PowerShot A470 Digital Camera
No image display on camera mode
There are different settings. You can view the past photos because you are using the viewer for that, but you have a setting off in the menu. You need to turn on view photo or preview photo after picture taken. I am not sure what it is in the Canon line, but look in your manual for the setting.
Jul 13, 2009 | Canon PowerShot A460 Digital Camera
Camera not turning off and when ON,always in picture preview mode
This is a problem on the motherboard, sort of like a solenoid that controls the functions of on/off mode and video still mode. it needs a service and possibley a patrt replaced Hope its unjder warranty as it expesnive
Jun 23, 2009 | Canon PowerShot S3 IS Digital Camera
Looks focused but isn't
Try this.
Switch D80 on.
Reset the camera by pressing the two buttons with a green dot beneath them on the top of the D80, right hand side.
The buttons are AF and +-.
These must be pressed together at the same time for a few seconds.
This is just in case you have set something strange, you do not need to do this all the time.
Set the command dial to Auto.
Set the button on the lower front/left hand side to AF.
Set the lens to A.
Now you can just take pictures, the D80 will autofocus and set the exposure itself.
Jan 01, 2009 | Nikon D80 Body Only Digital Camera
A630 clicks and wont take picture. Stays in preview mode.
Do you mean you are expecting it to show the photo that you just took for a few seconds before it goes back to preview mode? There's a menu setting which I think is called "Picture Review" and you can set it for something like 0, 2 seconds, 5 seconds, something like that.
I hope that was it.
-Vince
Oct 01, 2008 | Canon PowerShot A630 Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Olympus 5060 - buttons not working consistently
You can find a description of that problem and a fix here: http://www.wrotniak.net/photo/c-wz/c5060-dial.html
Oct 04, 2007 | Olympus Camedia C-5060 Wide Zoom Digital...
Cannot Record Videos
I would try changing the memorised info that you put into your My1 settings and see if that helps. I just got my V700 today and the first thing I did was put my preferences into My1. I don't really know why your camera is transferring this to your video setting but try removing your presettings in My1.
Jun 07, 2007 | Samsung Digimax V700 Digital Camera
Area captured in photo different from area saw in viewfinder
Make sure you look straight through the viewfinder. Keep in mind that the area visible through the viewfinder is slightly smaller than the area captured in the photo. If you're taking a close-up or macro mode picture, turn the camera dial to the LCD mode so that you can use your LCD screen to preview your picture.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Area captured different from viewfinder area
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
100 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
