Question about Sony CDX-GT300 CD Player
Sony CDX-GT300 just cut out
OK been working fine had turned the volume up quite loud and it cut out now it appears theres no power going through it at all.I checked the fuse and its fine , any suggestions?
  • Anonymous Mar 28, 2014
    had volume up to loud stereo cut out now wont turn on, ive tried fuese n connections all seems ok , can you help please?
By any chance, have you checked the main connector on the rear of the unit? I was having problems with the unit in my Harley cutting out and the front panel going dark and found that while the connector was still attached, the weight of the wire harness was tweaking it just enough to disconnect power. Try pulling, then reattaching the connector and if that fixes it, use zip-ties to take all of the weight off of the connector. Hope this helps.
Posted on Jul 02, 2009
I've got a Cdx-gt300 series that will not output to the rear or front out jacks on the back. Everything else works fine and the setting is set to sub out, but when connected and the sub is turned up to...
check the sub works with known good signal from different source. if that works and all settings are double checked then you might try to reset the 300 series to factory reset. try to unplug from the 110 outlet then hold the on button down while plugging it back in this should re iniatalize the unit and if it still doesn't work you may have a hardware problem
Jun 20, 2011 | Sony CDX-GT300 CD Player
The radio isn't working, I checked the antenna and it is ok. The CD works. I have a Sony CDX-GT300
You may have tuner problem on radio circuit. Please check and get it fixed.
Regards, Jay
Mar 25, 2011 | Sony CDX-GT300 CD Player
How do I set the time on the Sony CDX-GT300? Car came with the radio but time needs to be set.
http://www.usersmanualguide.com/sony/car_audio/cdx-gt300 and click on the user manual. Or www.docs.sony.com/release/CDXGT300.pdf.
Press and hold the select button until setup display appears. Then press select button until clock-adj appears.press dspl. Use the volume control to adjust hour. Press dspl to change to minute or back to hour. Press select when done.
Jun 21, 2010 | Sony CDX-GT300 CD Player
Volume control on in-dash unit not working properly
Sony CDX-GT300 volume control stopped working. Radio is either on full-blast, or you have to turn it off. Any solutions? Thanks!
Aug 03, 2008 | Car Audio & Video
No power!!
check the fuse box, maybe the fuse burned.
Jan 22, 2008 | Sony CDX-GT300 CD Player
Memory loss
you need to remove the radio and swap the red wire for the yellow wire and vice versa, they have bullet connectors to allow you to do this, basically the permanent live and the ignition live are the wrong way round.
Nov 27, 2007 | Sony CDX-GT300 CD Player
Sony/sirius
if it's only 10 months old send it back as it's still under warranty and won't cost you anything
Aug 14, 2007 | Sony CDX-GT300 CD Player
Sony CDX-GT300 CD Player Logo
182 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
