Question about Kitchen Ranges
Simpson supa-nova stove: right front element needs replacement. how to remove. where to get new one?
Element right front does not work. how to remove and where to get a replacement?
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
  • 136 Answers
SOURCE: Three of the four elements
just check out for the electric wiring diagram of your device given in this link for better help
http://www.applianceaid.com/image/microflowchart.JPG
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
on the fixya home page there is column called REPAIR SERVICEjust select the appliance category and enter the proper zip code of your area and the list of reparing person will be given with their phone numbers.you can just call them.
thanks.
Posted on Oct 13, 2008
aborcass
  • 2651 Answers
SOURCE: How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Posted on Nov 24, 2008
BNewberry
  • 93 Answers
SOURCE: how do you replace a burner switch on a Frigedaire Glasstop Stove
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Posted on Jan 10, 2009
I need a parts diagram to replace the right front surface heating element of a Kenmore range, Model 629-45775
Does the element have continuity? if so, it will be the element switch that needs replacement... Generally, the radiant element will be held on by two screws and a steel plate, note the wiring before removing the old part. Definitely remove power to the machine before doing anything inside of it... Kenmore Range Stove Oven Surface Element Switch WP7403P239 60
Kenmore Range Stove Oven Radiant Surface Element 12002141
May 25, 2016 | Kenmore Kitchen Ranges
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
May 26, 2010 | Ovens
Stove top elements on high only
Yarsu Spiros
I like you purchased one of these thinking you can trust the name simpson(pope) but after putting on a fry pan with sum saucages in and having a major fire in my kitchen, I through the heap of junk out and bought a *** oven (current technologie) howerver to answer your question you have pulled the elements and trays out to kleen them (that seems normal) but you need to make sure the element terminals are clean and so are the spring clip things they fit into, use a peice of emery cloth (not wet & dry) this should fix it
alternativly not buy this junk again and get a proper stove
regards Graeme
Auckland NZ
Jan 02, 2009 | Kitchen Ranges
Whirpool electric oven replacing bake element
In addition to what aborcass stated, I just had to fix the same problem. Remeber to turn off the power before you do this. On my stove the element acess is behind the side panel (right side when facing the stove). You remove two screws on the back and one underneath at the bottom, (you need to pull out the drawer). Once screws are out, slide the side panel forward gently about an inch and it should just drop off.
You should see the wires for the element level with the bottom of the stove. The wires will guide you to the element. And you should see that the element is screwed in with two screws to the stove. This is the tricky bit, to remove the element follow the metal piece holding the element to the right until you see a third screw. Remove this screw and the whole thing will come out. Take off the wires, replace the element on the metal strip, slide the element and metal strip back into the stove (take care to ensure the left side of the metal strip slides into the proper position under the metal clasp. Re-attach the screw, plug the wires onto the element and turn the power back on. You should have heat.
Good luck.
Dec 02, 2008 | Whirlpool GY396 Electric Kitchen Range
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Simpson harmony nova oven , oven is heating up but fan wont work and oven does not heat enough to use.
I had same problem. Replaced fan motor,really easy,but still would not turn. Got my brother inlaw to check it. Turns out it was the thermostat. He gave the connections a cleanup with sand paper, like you do car spark plugs. Works great,
Apr 28, 2008 | Kitchen Ranges
How to replace the solid element on a ge modelJ37SVWX electric range
removing burned out solid element on heartland stove and replacing with new one..It is enclosed with a chrome ring on stove top
Nov 14, 2007 | Ovens
Kitchen Ranges Logo
69 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
