Question about Refrigerators
F& P Elba Fridge/Freezer- fridge icing up in rear right hand corner model rf240b
Amigaman
  • 248 Answers
SOURCE: refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Posted on Nov 12, 2007
carldc3
  • 82 Answers
SOURCE: fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Posted on Jan 05, 2009
arikrom
  • 528 Answers
SOURCE: PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Posted on Jan 02, 2010
  • 572 Answers
SOURCE: Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Posted on Feb 08, 2010
  • 4793 Answers
SOURCE: magic chef mcbr1010w, fridge not
do a total, 24hour,defrost,with the doors open,(loads of towels)this should melt all the ice you cant see/get at.DO NOT use hairdryers/scrappers as they only do the surface ice.Wash out/spray all vents/drains with clorine bleach.(clorine is a gas and the smell will not permeate food if left to vent naturally) then switch onto fast freeze,check door seals are tight all round(hot cloth will help mould them).hope all works well for you/please leave feedback.ta!
Posted on Sep 22, 2010
Elba rf240b fridge freezer,,,,,freezer cworking fine but fridge no go...have defrosted and cleaned out drain tubes but still no cold in fridge
If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator".
http://electro-medical.blogspot.com/
Jan 23, 2017 | Refrigerators
Whirlpool ffw400wh cools nicely for 3 days then form ice on the freezer & does not cool at the fridge compartment
Sounds like your defrost timer is not functioning , it will need to be replaced. Some times the frost free fan can also cause this but I think it will be the defrost timer.
Located under the fridge usually on one of the rear corners.
Pit has like I white round dial on it .
Jan 09, 2014 | Whirlpool Refrigerators
Fridgidaire freezer warming up
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 09, 2013 | Freezers
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
I have a whirlpool 363L WRN38RWG6, the problem i am having is that the fridge leaks water from the vent inside the door on top of the fridge section, then the fridge freezes any thing put to the back of...
I could not find the model but i assume it is a side by side.The model # should be located in the fridge side on the upper right hand corner on the fridge wall.On the freezer side in the back there is a cover with vents covering the evaporator coils. Remove the shelves,the cover to expose the evaporator.If the evaporator is all iced up your defrost themostat may not be working.The defost thermostat is located on top of the coils,it is a little round unit with 2 wires going to it.To check you can uplug it and put a jumper wire in the plug in to see if the defroster starts up.Make sure the fan is also working.Also check the drain (little round hole in the bottem of the drain pan) below the coils.Just poor a little water down it.If it is pluged you can use a small round tube and push it through the drain.Hope this helps,if so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
Fridge temp goes up and ice forms in fridge
CHECK THE BAFFLE IT MIGHT NO BE OPENING OR CLOSING PROPERLY, THAT`S THE SMALL DOOR LOCATED @ THE LEFT UPPER CORNER OF THE FRIGERATOR
Aug 19, 2009 | Samsung Refrigerators
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
2003 Maytag Plus Dual Cool Side by Side
Check to see if the bacl of the fridge is iced over, if it is the fridge is not defrosting, 99% of the time it is the defrost control circuit board located in the upper right hand corner of the fridge.
Jun 09, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
