Question about Atlas Translator Marcato Atlas 150 Handle for Atlas 150 Pasta Machine
Rollers stuck ampia pasta machine
When trying to roll pasta , the crankd seems almost impossible to turn, but if the thickness knob is not engaged, then it turns
The knob on my kitchen aid pasta roller keeps getting stuck and i cant change the setting i need to be at
It needs either oil or the gear has slipped. A machine repair person, such as a sewing machine repair might be able to help you out for a small fee. Good Luck!
Oct 27, 2013 | KitchenAid Kitchen Aid Ravioli Pasta...
How do you disassemble ampia mod. 150 lusso pasta maker
Most can be removed by gently inserting a screwdrive under the edge and popping off. If it does not pop off easily, do not force it and have an expert do it.
Feb 08, 2013 | Marcato Ampia 150 Pasta Maker Made In...
My Imperia(dal 1932) Model is not holding the ravioli thickness when running through the machine. How can this be fixed?
There are parts breakdowns on imperia-parts.com and you can probably email them to get the older model parts too. I know they have a lot of stuff in stock.
Dec 02, 2012 | Imperia Kitchen Appliances - Others
Need replacement table clamp for pasta maker
Have you tried going to the manufacturer's website? I have this pasta maker on my website and you might try one of the links. But you will probably have to get a new machine. You could also go to your hardware store. They might have a clamp that you could use. Good luck.
Feb 21, 2011 | Atlas Translator Atlas 150 Deluxe Pasta...
Just bought Imperia RM220 that won't start at all.. WHat's wrong with that?
Just attach the pasta machine to your countertop, table or cutting board with the clamp.  Put the crank in the hole.  The pasta goes inbetween the rollers of course and turn the crank.  Start with the rollers furthest apart or the biggest number and roll the dough twice on each number.  There are videos to watch on my website:
http://noodlemakermachine.com/wp-admin/post.php?post=16&action=edit
 Good luck with that!
Feb 15, 2011 | Imperia pasta machine - Original Made in...
Pasta Machine turning pasta sheets out with lots of holes? What are we doing wrong?
Start with the rollers farthest apart and when you first start rolling the dough will be uneven and have a few hole. But as you roll the dough over and over, it will be smooth with no holes in nice flat sheets. Rollthe dough twice on each setting, starting with the biggest number and rolling down to the smallest number for very thin sheets of pasta. Good luck. I have a recipe and videos on my website at http://noodlemakermachine,com.
Jan 16, 2011 | KitchenAid Kitchen Aid Pasta Maker...
Why my dough is tearing when i try to make ravioili?
You have to let the dough rest about 30 min. to 1 hour before passing the pasta in the roller. Also if you put some flour on both side of your pasta for the first passing through the machine it works well.
Jul 21, 2009 | CucinaPro Cucina Pro 150-25 Pasta Ravioli...
I want to make ravioli in my pasta maker...
All the models of raviolis makers are not graduate identically...So I have the Kitchenaid ravioli maker and the #1 is the larger and the # 8 is the thiner. For the raviolis the best thickness is the #5 or 6 and all is perfect for me and delicious. Also here is what Kichenaid suggest for the thickness of the dough: If you do not own a KitchenAid Pasta
Sheet Roller, pasta sheets can be prepared
by hand. Pasta sheets should be rolled out
to a thickness of 1/16" (0.156 cm). Hop this help!
Jul 21, 2009 | Norpro Atlas/marcato/norpro Ravioli Pasta...
Atlas Translator Marcato Atlas 150 Handle for Atlas 150 Pasta Machine Logo
41 people viewed this question
Top Atlas Translator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Atlas Translator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
