Question about IBM ThinkPad R51 Notebook
I/O device solve my ii/o device problem
System will not turn on, but I can plug another device into the external ac power plug and that device turns on. What could be the problem?
The problem could be with your power adapter in which case it will be fairly easily solved. If there is another device with a similar power adapter, check that. If the power adapter is fine, then you need to call the customer service guys for your Karaoke System.
Aug 30, 2015 | Vocopro GIGSTAR-PRO-II Professional...
What are the external power ports used for on the DX-ESATAP 2-Port eSATA II PCI Express?
they provide dc power for esata devices should have Included a 4-pin internal connector and 2 DC power cables let me know if that solves your problem
Mar 19, 2011 | Dynex DX-ESATAP 2-Port eSATA II PCI...
Low voltage Error, Citizen CBM 1000 II thermal printer.
check fuse 2 as this would cause the 3 short 1 long flash code. Even if its not blown at least you can trace that part of the crcuit for other blown devices
Aug 02, 2010 | Citizen CBM 1000 thermal Printer
Making calls and sending SMS by Omnia 2 (it failed).
Omnia II i8000 no sending mms massage received ok what is the problem use factory os WM 6.5 pro
Jan 09, 2010 | Samsung Omnia II I8000 Smartphone
Having trouble connecting Explorer 320 to Samsung Blackjack II
Push And Hold The On Off Switch On The Blue Tooth Till It Flashes Blue And Red. Then Search For The BlueTooth When Found Push The Button On The Blue Tooth Again. Hope This Helps
Jan 04, 2009 | Plantronics Explorer 320 Wireless Headset
No sound
I am Satya.
The problem can be solved in the following ways for Windows users:
1.i.We need to click on Start Button.
ii.Next we need to click on Control Panel from the start menu.
iii.From the control panel window we need to click on "Sound & Audio devices" icon.
iv.From the Sound & Audio devices properties window we need to uncheck the Mute checkbox.
I hope this will solve the problem.
If it doesn't try this:
2.i.We need to right click on My computer Icon from the start menu.
ii.From the menu we need to click on properties.From the system properties window we need to click on Hardware Tab.
iii.Next we need to click on Device Manager button.
iv.From the device manager window select "sound,video & game controllers".
v.Right click on it and from the new menu click "scan for hardware changes".
Now proceed to play any audio file.If you get an audio output then the problem is solved.
In case you don't get an audio output click on the + sign next to "sound,video & game controllers" select "legacy audio drivers" and from the Action menu in Device Manager window click on "update driver"
Follow the steps as mentioned in the update driver wizard,by downloading the driver from the internet.Click on Next.
After completing the driver installation.
check with the audio output.
If this solves the problem then you are done.
If this doesn't try installing the Audio driver from the Driver CD that you had received when you purchased your notebook.
Hope this has helped to solve your problem.
Thank You & have a nice day!
Aug 14, 2008 | HP Computers & Internet
O2 XDA II Grounded? (No one Cant Solve it)
Do you use a USB mouse then it may be due to conflicts and it has recognized it as another device .... try other USB port.. it may solve ur problem
May 15, 2008 | O2 Xda II Smartphone
Privacy lock on Sidekick II
how do i solve this thing 3-digit privacy lock code
May 01, 2008 | T-Mobile Sidekick II
Blackjack II internet stops working....
Hello again dogbyte!
Fantastic! I'm thrilled to here the first fix went well!
Here's the deal on your most recent question...(Please excuse the long post - I'm intimately connected to this particular issue, so I figured I'd try to share some of the background on it.) Are you using GoodLink version 5.0.x by chance?
Our team has actually submitted bug reports to both GoodLink and AT&T on this issue. The BlackJack II has a connection setting called "AT&T IMS" (supposedly there to offer additional features on the AT&T network sometime soon.) Unfortunately, when GoodLink 5.0 is provisioned on a BlackJack II with this particular GPRS connection setting, internet problems are basically guaranteed.
The BlackJack II will successfully connect to the internet to download, install, and synchronize GoodLink. The first time the device disconnects from data services (i.e. - roams out of data coverage, the device is powered off, the device hits critical battery, etc.), data will not reconnect.
You've got two options:
I. Delete the "AT&T IMS" GPRS Connection Setting
1) Navigate to Start > Settings > More... > Connections > GPRS
2) Use the multi-directional pad to highlight the AT&T IMS connection.
3) Click Menu > Delete
4) Press Yes to confirm the delete.
5) GoodLink and Pocket IE should be able to connect to data services again in 5-10 minutes or less.
Note 1: Solution I needs to be performed again if the device is hard reset. If your user(s) need to hard reset the device upon occasion, you may want to make the instructions above readily available to the user, OR consider option II to prevent confusion (if option II is available).
Note 2: Changing the Access Point Name on this connection from "ims.cingular" to "wap.cingular" can also solve the problem, but it's not always consistent.
I. Provision the BlackJack II with GoodLink 4.9.3.x.
This last stable release for GoodLink 4.9 seems operate without the same data issues. Although Good 4.9.3.x doesn't offer some of the more robust features of Good 5.0 (such the ability to send email attachments from the device or RSS feeds), we've been deploying Good 4.9.3 to BlackJack II users since we discovered this issue a little over two weeks ago, and it's definitely made a postive difference.
Another Potentially Related Issue
You may also notice surprisingly frequent "403 Forbidden" messages in Pocket Internet Explorer on AT&T devices (including the BlackJack II).
All Internet Explorer traffic from an AT&T device goes through AT&T's proxy. AT&T's proxy apparently includes a rule that disconnects a user if they haven't used the web for a specific period of time (I've heard 2 hours, but that may vary). Unfortunately, AT&T and Microsoft haven't figured out a way to simply open that Pocket IE connection back up... at least not easily.
If you're seeing "403 Forbidden" errors, you'll want to do one of the following to close and reopen the data connection:
I. Reboot the phone
(closes and reopens all of the connections)
II. Manually disconnect cellular data
1) Click the Power/Quick List button on the top of the BlackJack II. The "Quick List" should appear
2) Select Wireless Manager
3) Click Menu > Disconnect cellular data
(You should notice the "MEdia Net" indicator under "Phone" change to "On")
4) Click Done to return to the Homescreen.
5) Open Internet Explorer again and navigate to the desired page.
Note: Although the "403" error doesn't necessarilly interfere with GoodLink connectivity, manually disconnecting cellular data will. If you don't open IE an actively open a data connection to reach the web, you'll probably want to open GoodLink and do a quick manual Send/Receive, just to make sure that it re-establishes its connection.
Sorry for the book! I hope one or both of these help.
Have a great weekend,
The MoDev Kid
Apr 18, 2008 | Samsung BlackJack II Smartphone
IBM ThinkPad R51 Notebook Logo
71 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
