Question about Garden
How do i respool my makita rst210 - Garden
3 Suggested Answers
  • 2468 Answers
SOURCE: Makita RST210 grass trimmer not idoling and backfiring
your muffler has gotten full of carbon from the oil/gas mix you use and now theres too much back pressure and needs to be removed and cleaned or replaced,also while its off clean out the carbon deposits on the reed valves at the exhaust port
Posted on Mar 08, 2010
rycgl
  • 1545 Answers
SOURCE: makita rst210 (brand new). Engine runs well but
I would like to suggest that you follow the warranty instructions for this machine and go about getting another unit. I'm sure if it is a Makita, that there is a valid warranty for it. The clutch is centrifugal and if it is not working, much disassembly is required.
Posted on Jan 09, 2011
My RST210 2 stroke petrol strimmer won start it has a spark at the plug also the plug is flooding so fuel is getting through but non start ? Great full for any ideas
Often it's the easiest thing that stump us. Try changing the spark plug first. Sometimes a spark plug just won't fire under load, i.e., while it's in the cylinder but will spark if you have it removed. There are checkers for this, but it's a lot less expensive to just replace the spark plug. Do that first and let me know.
Sep 28, 2014 | Makita RST210 2 Stroke Petrol Line Trimmer...
One litres to a gallon
One US gallon is about 3.79 litres. One imperial gallon is about 4.55 litres.
Jul 20, 2014 | Makita RST210 2 Stroke Petrol Line Trimmer...
Riso RP 3700 T12-305
t12-305 The master compression sensor does not go ON within 6.5 s after the master compression motor operates in the return direction.
kindly try to check your master roll and respool it. the problem could also be because your master cannot be dispose the old master properly. remove the old master and respool your master roll and initiate your machine or turn it of and turn it on again. hope to be of help.
Dec 27, 2013 | Riso RP 3700
Makita line trimmer pull cord
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you. gtui
Jan 30, 2012 | Makita RST210 2 Stroke Petrol Line Trimmer...
How do you respool a "slipped off" drive belt on a
manuals.mtdproducts.com/mtd/GetFile.do?filename=769-02100.pdf
Apr 17, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Makita rst210 (brand new). Engine runs well but cutting head won't spin. how do you release/apply clutch?
Jan 08, 2011 | Garden
Need to respool a 404
As an avid fisherman myself I know the value of fresh line. Here is a great link that shows the step by step for respooling the 404
http://www.trails.com/how_24764_respool-zebco-reel.html
please mark my answer as very helpful. thank you. Joe
Apr 05, 2010 | Zebco Omega Spincast Reel
How to respool an electric Weed Eater Trim and Edge RTE 115
The nylon string is simply spun onto the emty spool. There should be an arrow on the top of the spool indicating the direction to wind the line. If the spool is missing a notch to hold the line to get started, use your finger to hold it in place for a few full wraps.
Apr 03, 2010 | Garden
Mar 08, 2010 | Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
