Question about Sanyo Used Original 076E0RU011 Remote Control
Program code for sanyo 076e0ru011 - Sanyo Used Original 076E0RU011 Remote Control
How to program my sanyo in ph_el3b
[PDF]Programming Remote Control Brand Codes TV Sets cvalley.net/sites/default/files/ADBz_Remote_0.pdf
  1. Cached
  2. Similar
Sanyo. 0154 0208. 0157 0484. 0292 0721. 0036 0011. 0370 0339. 0072 0216. 0217 0104. 0045 0555. 0146 0009. 0544 0163. 0037 0108. 0159 0556.
How do I program the Audio Sonic Universal Remote Control PH-EL3B?
www.fixya.com/support/t25775411-program_audio_sonic_universal_remote
  1. Cached
  2. Similar
Jul 8, 2015 - Then to enter code 5 for my Sanyo set. This does nothing. Nor does manual entry of the Sanyo codes from the accompanying booklet. And if I ...
Nov 29, 2016 | Sanyo Televison & Video
Need a code to program a sanyo fxre
Kathy, code to program a sanyo fxre. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://bucksbackup.weebly.com/blog/download-free-how-to-program-a-sanyo-fxrd-remote-software
How to Program Sanyo Universal Remote eHow
Welcome to Remote Central Universal Remote Control Reviews More How to Program Universal Remote https://electrohelponline.blogspot.ca/
Apr 10, 2015 | Sanyo Televison & Video
How do I program a Sanyo TV with a GE universal remote version LRO3,1.5?
try to check the web who makes sanyo, probably now panasonic. try panasonic codes-- only if all sanyo codes don't work. (just in case... make sure you follow the steps in the programming code. try to program another component such as a dvd to make sure you are doing the programming steps right just to be sure so as not to waste time in trying other codes.)
Nov 28, 2014 | GE Televison & Video
I need the code to program a sanyo tv using the one for all untiveral remote URC-2060
If you do not have the code for you Sanyo TV then you can use the remote itself to get the code. It is a bit painful as you have to count the number of blinks it makes.
Follow the steps under getting your code.
Also it would help if you provide the model number of your sanyo TV in the comments section.
How to Program your One For All remote
Aug 17, 2014 | Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need the code to program my sunflwer remote with my sanyo tv
try these 014 / 032 / 045 / 075 / 120 / 121 / 122 /123 / 124 / 163 / 168 / 171 / 183 / 196 / 206 / 305 these are for all diffant sanyo tv and if your remote needs more than a 3 number code sorry can not help
Nov 28, 2009 | Sanyo Televison & Video
I have a rca 311 w to program into a sanyo tv
Code For Model RCR311W
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Jun 05, 2009 | RCA RCR311B Remote Control
Need codes for sanyo tv
I HAVE A UNIVERSAL REMOTE CONTROL AND A SANYO TV
TO PROGRAM WITHOUT THE BOOK OF CODES. HOW CAN I GET THE CODE TO PROGRAM THE REMOTE CONTROL FOR A SANYO TV ?
Mar 13, 2009 | Televison & Video
Sanyo Used Original 076E0RU011 Remote Control Logo
43 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
