Question about Delta 4-speed, 3-roller Stock Feeder
How much Oil in delta stock feeder 34-994 - Delta 4-speed, 3-roller Stock Feeder
Will not turn on.
I bought one that didn't work, and ended up just buying a new control board assembly for around $75. It was an easy fix that just required a screw driver and about 10 minutes.
Feb 08, 2011 | Delta 36 865 1/8hp Versa Feeder Stock...
I NEED A REPLACEMENT GEAR PART NO 1347788 FOR A DELTA 31-780 SPINDLE SANDER
The link below includes the schematic, part list, pricing and ordering info for toolpartsdirect.com
Delta also offers this model in 2 other variations, 31-780 type 1 and 31-780 type-2. Both of this are also available from the page this link will take you to. The part you are looking for is $13.33 and they show 4 in stock.
Have a great day.
Dec 28, 2010 | Delta 31 - 781 Sanding Spindle Set for 31...
I need a index spring for my 36-220 compound
Exploded diagram for 36-220 is here.
Operators manual is here.
Once you have ID'd the index spring on the exploded diagram, you should be able to order it from Delta, assuming it's still a part they stock. If they no longer stock it, you may be able to find someone who does still stock it by a google search of the part number.
I've got a bad feeling this part may be very difficult to acquire though.
If this answer was useful, please vote. Thanks.
Dec 20, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
My 13 inch delta planer will not feed the stock through the planer. Any suggestions why?
I have a 12" Portable Planer Delta Model 22-540 - Planer will not feed the stock.
Sep 09, 2009 | Delta 22-450 20" Planer DC-580 3-Phase, 5...
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
1999 Oldsmobile Delta 88
seriuosly? refer to a haynes car repair/maintence manual. a lil messsy and a lil time but yes you can do it fram oil filters and mobile 1 synthic oil are the best to use.
Sep 21, 2008 | 1989 Oldsmobile Delta 88
Document jam
There is most likely a very small piece of paper in the document feeder.
What you can do is take a minella folder or some card stock, open the document feeder cover and shove the folder or card stock through the feeder to dislodge whatever is stuck in there.
The document sensor itself may be knocked out of position.
It can't be the copy paper path since you can print.
May 16, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Delta Luv Crib 4600 (1997 model)
That's probably older than their support line stocks. Consider using archive.org to see if a later model uses the same part? I called 800-377-3777 on a 2001 model crib and ordering parts was no problem.
Mar 08, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Delta 4-speed, 3-roller Stock Feeder Logo
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
