Question about Boating
What year is my gamefisher 5hp outboard motor vin# 0E105312
Model # 225-587-505
3 Suggested Answers
  • 65 Answers
SOURCE: where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
water pump is in the lower end of out drive and there is no t-stat
Posted on May 08, 2009
goldbill
  • 184 Answers
SOURCE: Water circulation (coolant) thru outboard motor
Keep spritzing water on the power head and look for heat, If not pumping, the exhaust plate on those got real hot real fast. Many had heat sensitive paint and the white turned brown pretty quick,
Posted on Jul 29, 2012
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Install ignition points on 9.9 gamefisher
remove flywheel remove old points and install new set. set gap ,replace flywheel,
Oct 21, 2014 | Light Outboard Motor Boat Bass Fishing...
I have an old 15hp gamefisher that's not getting fire
Have u got spark ? Put new fuel in flushed carb and fuel lines ?
Mar 18, 2014 | Light Outboard Motor Boat Bass Fishing...
Evinrude outboard motor serial number c7108106
The Manual Store also has some useful boat motor model year lookup data:
Boat Motor Model Year Lookup Guide
Jun 30, 2013 | Boating
I bought a 5 HP gamefisher outboard motor. It 's been use once and then it sit for years outside. I change the spark plug,clean the carburator,fuel filter looks good.good compression. gas go all a way to...
If spark plug is dry, fuel is not getting to the cylinders. Next thing to check would be the fuel pump... Gas may be getting to carb, but the pump needs to push it into the cylinders too.
Oct 18, 2009 | Boating
Where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
May 05, 2009 | Boating
Common problem is the thermostats staying closed. If i remember correctly they should be replaced every year. Water should be spitting out on the upper part of the shaft. Good luck on that fishin'
Apr 25, 2009 | Boating
Boating Logo
50 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
