Question about Zoeller Aquanot II Battery Backup Pedestal Sump Pump - 585 - 585-0005
Battery charger is making loud noises and smells like its over heating. It is constantly running, too. The battery is 1 year old and was just refilled with distiller water last week.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Makes loud hum and faint smell when turned on
It sounds like your magnetron failing.
If a fuse were blown, it would be totally dead with no lights, no display, etc.
Keeping it out of the landfill a while longer by getting it fixed is always an option.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Nov 20, 2008 | Goldstar MV-1501 Microwave Oven
Microwave makes loud noise and does not heat. Smell of light burning
Chances are you have a bad magnetron.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Microwave Ovens
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
yes anything can be fixed but a do it yourselfer i reccomend against this cause thats a radiated element in the micro
recommend go out and purchase a replacement go with G.E. they have the 7 year warranty great little micro. too change out is easy
Jun 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Zoeller Aquanot II Battery Backup Pedestal Sump Pump - 585 - 585-0005 Logo
54 people viewed this question
Top Zoeller Plumbing Experts
Paul Nicholson
Gil Shultz
Are you a Zoeller Plumbing Expert? Answer questions, earn points and help others
