Question about Toys
How do you remove the fuse panel from an 873 bobcat
3 Suggested Answers
  • 582 Answers
SOURCE: Hydrolic arms wont lift up or down on Bobcat
CHECK ALL THE SAFTEY SWITCHES ON THE SAFTEY BAR . IF THE UNIT MOVES FORWARD AND BACKWARDS THE SWITCHES AREN'T THE PROBLEM
Posted on Aug 23, 2009
Testimonial: "The unit will move forward and backward. And the auxillary hydrolic switch works. I can also get front and back tilt, just no up and down."
  • 1212 Answers
SOURCE: replace main drive belt on clark bobcat 873
It is is supposed to have a spring tensioner like the one on your daily driver.
The bushing may have worn enough for the idler to have fallen off the one you have. They would have been the bolts you kept getting the belt hung up on as you threaded the belt on the pulleys. If the spring itslef brokey you need the entire idler assembly.
Posted on Jan 07, 2012
My 873 Bobcat aux hydraulics turn the wrong way it was working fine but now turns only clock ways, what is wrong
this model has got something called bi directional valves on the remotes , meaning it can move both ways , now there can b three reasons for this to go only one way , first the simplest is , what is called a lock-out reverse setting , this forces the remotes to move only one way , (there should be a note in manual about this) the second reason is the directional control valve is defective , and last but not least if your ffeedding a hyd motor with this , the motor could be defective and its only moving one way and not with much force either (a simple sub out of an std cylinder would show this)
Aug 24, 2016 | Bobcat Garden
How does the fuel system work on a 873 bobcat
first replace the fuel filter, if that doesn't fix the issue, then perhaps you have compressed springs in the fuel pump, or debris in the tank blocking the fuel pick up.
Mar 06, 2015 | Bobcat Garden
Bobcat 873 not getting fuel
it could be pump. ive also found that the pickup tube breaks off causing the pump to suck air. also hows the fuel filter? could be a problem also
Sep 14, 2014 | Cars & Trucks
1997 bobcat 873
replace motor you blown a ring i mean short block the motor take to a lawn shop are a equipment dealer i have a lawmmower shop i would work on it
Sep 08, 2014 | Garden
Miller bobcat 250
remove the side doors, and top cover, make sure your brushes are making correct contact against the slip rings, there is a flat mounting panel behind the range control switch, you will see 2 white fuses in their holders, check these fuses, one controls AC output the other controls weld current output.
May 19, 2014 | Welding Tools
Replace main drive belt on clark bobcat 873
Jan 06, 2012 | Welding Tools
Hydrolic arms wont lift up or down on Bobcat skidsteer 873
Aug 23, 2009 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
Toys Logo
240 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
